Results 1 to 10 of 27
Thread: Updated: Mod No.2: CD70 with Reversing Camera
    Cool Updated: Mod No.2: CD70 with Reversing Camera
    Ok, after I posted this thread last year...
    ...I've been planning for a long time to do a more permanent install with a better camera. Everyone who's seen it knows the camera I had was mounted on the inside of the car at the top of the rear window, where it was fine during the day but at night the infra-red LED's just reflected off the windscreen. I sort of knew this would happen when i first fitted it, but I was more interested in getting the whole thing working and proving to myself it could actually be done.
    I had managed to wire the camera into the factory fit parkign sensors so that I could manually operate the camera jsut by pressing the Park Pilot switch, as shown in the video. I was quite pleased with this, as it worked well and meant I didn't have to put it in to reverse every time someone wanted to see it work...
    With a couple of weeks off work, my dad's garage, a load of electrical tooks, heatshrink and numerous cups of tea curtesy of my mum I set to work.
    First things first, I ripped the rear bumper off, along with the left side of the interior to get at the wiring which had been simply hidden and put together with terminal blocks.
    This is what a Signum looks like with it's ass in bits:
    And I also found these on the right hand side. Haven't the foggiest idea what they're for.
    The bumper is unbelievably easy to take off, and I set about it with a holesaw. The new camera I had was a round bullet type the same as Danboy has, and mounting it outside would make the camera useful at night instead of just the day. As anyone who's fitted parking sensors to the rear of a Signum will know, you also have to drill in to the crash bar as it sits directly behind the bumper. I didn't see this as a major problem as it comes with 4 massive holes from the factory if you have parking sensors fitted anyway, so one more hole wasn't going to hurt...
    I soon came across a problem when getting the camera to work. After much experimentation, it transpired that it needs a full 12V to work, whereas the old one could get away with 8V. The problem this presented was that the parking sensors which I'd taken the feed off for the first camera operate on 8V, which wasn't enough to work the camera. I could hook it in to the reverse light circuit, which is what I eventually did, but it meant I wouldn't be able to operate the camera via the park pilot switch.
    My dad, being the way he is, built a small relay which I could have used to operate the camera from any 12V source via the sensor 8V line, but as I'd already sorted out most of the wiring down the back end with heatshrink, proper connections and tie-wraps I decided to leave it as it was. It now only works off the reverse gear, but that's all it needs really.
    The result:
    The other option I wanted to explore was using the other 2 inputs the interface board comes with. there are 3 in total including the dedicated reverse camera AV input, but the other two are selectable with a lit-up switch. Up till now this has all been hidden behind the dash, but I wanted to add it in somewhere and make it useable tbut still keep it out of sight.
    My car came with bluetooth from the factory, but everyone knows the kit that sits between the front seats is pointless and I got a coin tray with slidy cover to replace it. After lots of faffing with wiring, 12V supplies and a huge number of scratches on my hand, this was the result:
    It lights up when the ignition is on and you can plug any NTSC AV feed into it, press the button and the screen will switch over to it. There's another AV cable tucked behind the dash which I'm saving for future plans...
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Would love to do this on my NCDC great write up mate
    Irmscher Insignia CDTI 130
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    someone's been busy... nice work Martin. That's one fully loaded Sig.
    Quote Originally Posted by lofty View Post
    I was looking at the folding mirrors last week - unfortunately even with all the kit mine's got it's still got the wrong door modules - that adds a severe amount to the price unless you can get the discounted...
    Wales, UK
    Even better than before, fantastic. I love the extras in the coin tray....
    Quote Originally Posted by mark_647 View Post
    It was the only place I could think to put them where they would be easily accessible but could be hidden out of sight and still make the car look OEM...
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    that looks spot on its a shame they didnt do that as standard like on the nissan primera!!
    Mar 2007
    North East
    Very tidy
    The insignia has similar flaps in the rear side wells of the boot, I just assume they are something to do with ventilation.
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    Cool mod
    The bits you mention on the right hand side, i think they are pressure vents, to stop excessive internal pressure when driving with a window down....and blowing the rear or side windows out. Had them in my Clio and that was th explanation I was given.
    Regular Member Baz07's Avatar
    Lancashire
    Someones been busy but well worth the effort.
    So does the CD70 Navi unit come with AV inputs then, just that i have seen so many links to videos showing them playing either camera views or tv/dvd picture...And is it as easy as plug and play?
  1. Mod No.2: CD70 with Reversing Camera...
    By Penfold101 in forum Electrical & ICE (including SatNav)
    Last Post: 1st November 2013, 00:08
  2. Replies: 10
    Last Post: 3rd June 2012, 19:33
  3. Reversing Camera
    By lizard in forum Styling
    Last Post: 3rd July 2010, 20:44
  4. Reversing Camera - Which One?
    By System in forum Electrical & ICE (including SatNav)
    Last Post: 18th February 2008, 20:06
  5. Reversing Camera
    By Caterman in forum Electrical & ICE (including SatNav)
    Last Post: 3rd July 2006, 22:07
Vauxhall CD70 navi Reversing Camera System
vectra cd70 reversing camera
installing reversing camera into cd70
front parking sensor vectra c how to instal
how do i modify my cd 70 navi system so i ca. fit a rear camera
vectra c front park pilot
