Results 1 to 10 of 13
Thread: Creaking on rear and squeaking on front.
    Default Creaking on rear and squeaking on front.
    Right I've had a knock on the rear when going over bumps since I bought the car 3 weeks ago, now I'm looking at what it could be so I can get it sorted as its starting too annoy me, it happens over any bumps really, but gets louder the bigger the bump.
    Also front drivers side, has like a creaking noise when breaking, thinking maybe the springs is about too snap or shock ruined? I've had a little look at the spring and it doesnt look like its snapped from what i can see.
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    19 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 218,000
    Is the rear-end noise a knock or more of a rattle? Mine was making a nasty rattle over speed bumps and broken surfaces. I replaced the upper control arms and it has cured the problem. It's nice and quiet now.
    I had nasty crunching sounds from the front end too. I replaced the front anti-roll bar drop links and it is now very much better - I'd say 80% improved. I think ideally the front ARB rubbers could do with being replaced too but it's okay for now.
    Just my experience and it may not be what is wrong with yours.
    Paul
    2003 Vauxhall Vectra GSi 3.2 V6
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quick test for the rear....grab a hold of the road wheel at 12o'clock and give a few sharp tugs, if the upper control arms are knackered you will here a clunking noise.
    As for the front the sqeaking may be a dry joint or arb drop links
    Cheers for the advice, shall go out and check.
    Hanging Heaton / Batley
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Creaking rear is def the arms, just had mine done today and the silence is awesome...
    I did the ARB bushes just before, and it just made it slightly less creaky...
    19 Post(s)
    Trim : GSi
    Engine : Z32SE
    Mileage : 218,000
    Quote Originally Posted by leemarksmith View Post
    I did the ARB drop links in mine and it made a massive difference, leaving only a slight creaking when the car has not been driven, so that would suggest to me that you may need to replace the drop links.
    Paul
    23 Post(s)
    Mileage : 110k
    Talking about the rear ARB bushes mate
    But my fronts do need doing also, but i can live with the front creak... But the rear arms started to creak just driving on flat roads - sounded like an old creaky bed everywhere i went
    yeah just gave the rear wheel a good pull and it was knocking, how much roughly would this cost too sort??
    23 Post(s)
    Mileage : 110k
    I got these, so nice and cheap... Vaux want more then that for 1...
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...#ht_1107wt_939
    19 Post(s)
    Trim : GSi
    Engine : Z32SE
    Mileage : 218,000
    And fit 'em yourself. It took me about two hours or so but I have not done much on my Vectra. I am just starting out as a Vectra DIYer! But, as long as you follow the principles in the How2 thread, you'll be fine.
    Paul
  1. Creaking / squeaking drivers seat
    By Chip in forum Bodywork & Interior
    Last Post: 2nd August 2012, 21:08
  2. squeaking from ns rear
    By paulf in forum Suspension, Wheels & Brakes
    Last Post: 10th February 2010, 21:53
  3. Squeaking From Front Drivers Side
    By Stephen S in forum General Chat
    Last Post: 16th June 2009, 21:20
  4. creaking from front and rear calipers
    By k3vx in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2009, 21:01
  5. front l brake squeaking i think anyway
    By junior72 in forum Suspension, Wheels & Brakes
    Last Post: 14th August 2008, 23:23
Front end squeak on corsa 2003
vectra rear droplinks squeaking
squeaky caliper on vectra c 3.2 v6
corsa d rear squeak
vectra c rear end creaking
z19dth turbo squeak
