Results 1 to 10 of 16
Thread: Feast your eyes on this marvel of technology!
    South Central England
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Default Feast your eyes on this marvel of technology!
    This is my attempt at a switching unit for my two tuning boxes, about £700 worth of gear there! Doesn't work. I tried it earlier and hit some problems but I don't have my multi meter with me and I think it is a loose connection in the wiring from the engine bay to the cabin. So I'll falt find it when I get hold of my multi meter.
    Theory though,
    1) a switch to select which box to use
    2) another switch to change from normal to using the box
    The output from the boxes is lower than the normal signal so when the switch is made to connect the sensor output dirrectly it operates normally. When the switch breaks that flow, the box that is connected at the time gets to push it's signal through.
    The resistors don't do anything, they just happen to be on the board
    Regular Member S888 SRB's Avatar
    May 2006
    Hemel Hempstead, Herts
    I don't know what to say!
    Keep us updated and i'd like to see some more pics and the results!
    Regular Member Harry's Avatar
    Uxbridge, London
    hope you get it sorted Nutron! alot of hassle IMO, but each to their own.
    Regular Member jonno_07's Avatar
    Apr 2006
    beverley
    looks like a school electric lesson only much more complicated. hope you get it sorted
    Melbourne, Australia
    I know less than nothing about "tuning boxes", but it looks like the three circled wires aren't connected to anything - could that be the problem?
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    That's where I take the lines for the two boxes and the standard signal to the switches. By the way, if anyone else has more than one tuning box, the connections in the cables are different in these two at least (Tunit CR3 and D-UK CR2), so don't try swaping them if one cable looks better than the other.
    Regular Member Matt21385's Avatar
    Ayrshire Scotland
    Trim : VXR
    Engine : 2.8 V6
    WTF are you up to now mate will be intereting to see it when you get it working
    You're a brave man! Will be interesting to see if you can get it going though.... then a letter to the patent office might be in order!!!!
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Tried it out from the engine bay and it didn't stall (which is good). So it must be a problem with the lines to the switches.
    Can't really climb out on the bonnet while doing 60mph to try and turn the box on or off, not even I'm that MAD!
    Leicester
    Seen that before, it was on the bonnet of a Delorean in a cave in 1885, something to do with time travel.
  1. Technology
    By Stevel in forum The 'Off Topic' room
    Last Post: 11th January 2009, 23:50
  2. modern technology
    By lindsay1411 in forum Comedy & Humour
    Last Post: 29th July 2007, 23:56
  3. latest technology
    By howey in forum Comedy & Humour
    Last Post: 23rd May 2007, 00:07
  4. Wonder of technology? My a**
    By R-man in forum General Chat
    Last Post: 21st November 2005, 10:07
  5. Technology...
    By C19_CJB in forum Comedy & Humour
    Last Post: 29th July 2005, 22:46
