Results 1 to 10 of 18
Thread: empty fuel???
    Regular Member SRimonkey's Avatar
    wednesfield
    Default empty fuel???
    father in laws vec b on me drive now,he`s gettin rid for a new car cos fuel pumps gone........how do i get the full tank of diesel out quickly,won`t syphon!!
    Mileage : 000
    You will not be able to syphon it out. The Vectra B has an Anti syphon neck.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Remove in-tank fuel pump.... insert hose.... syphon into suitable approved fuel container.
    wednesfield
    gotta drop the tank for that tho........mine ain`t diesel anyways but he don`t wanna give scrap man a full tank of diesel
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    REMOVE A PIPE AT THE ENGINE BAY! FIT A SUITABLE PIPE TO PUMP IT OUT!! do this by just turning the key on+off!! (the elec fuel pump will do it for you) just done the same thing with a peugeot. what rg is it ? aint it worth picking a pump up from a scpappy.
    wednesfield
    pumps knacked m8.......or will that do it still
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    If it's only going for scrap, drill a 10mm or so hole in the lowest point you can.... let the fuel drain out then plug the hole with a suitable epoxy repair putty.
    Quote Originally Posted by the-wizard View Post
    You wont have an electric pump in the fuel tank on any Vectra with the 2.0/2.2 dti engines fitted , its only the cdti engined models that use a tank mounted pump. (and petrol models of course)
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    A vec B will not have an in tank pump (even the Vec C DTi's don't)
    Best bet is to cut the fuel lines under the tank and let it run out
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    there should be a elec pump in the tank that feeds the pump in the engine bay!! turn key on / off you shoud hear it !!
  1. what to do when the bottles are empty
    By opel_estate in forum Comedy & Humour
    Last Post: 8th June 2012, 13:56
  2. russi666....Empty your box
    By blues n twos in forum General Chat
    Last Post: 11th February 2009, 19:26
  3. Cam follower empty!!!
    By Dunc in forum Engine & Drivetrain
    Last Post: 17th August 2008, 11:54
  4. Big empty hole....
    By Cragy in forum Vectra C / Signum Car Chat
    Last Post: 29th January 2008, 22:55
can i syphon diesel from a vectra sri 2007 model
