Thread: Help..Clear spanner light by disconnecting battery?
    Regular Member marky2027's Avatar
    Northumberland
    Default Help..Clear spanner light by disconnecting battery?
    Car was in dealers a few weeks ago to have intake manifold and glow plug sorted (EML was on due to glow plug fault). The thing is I've noticed today that the spanner light is on only with the ignition and goes off when the car is started. Car is running fine. The thing is has this light been on since I picked it up from the garage? I don't think it has TBH. I am presuming that it is a stored fault code and I may not have noticed it. Thinking of disconecting the battery for an hour to see if it clears. I have got the radio code and security code. What settings will I need to reset when I reconnect? I'm slightly worried that central locking won't work and the wife is worried that the car won't start!!
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    dont take my word for it !, but i had mine 04rg disconnected all day and all i had to do was set the elec windows by just sending them down and back up again, plus the radio.
    Northumberland
    Are the windows preset to one touch facility? is there a certain procedure to follow once battery is reconnected??
    Apr 2009
    Leeds
    thought light always came on wi ignition then off wen started
    Regular Member goosey_1976's Avatar
    Nov 2009
    Dunston, Gateshead
    Vehicle : Insignia 2.0 SRi Nav
    Trim : SRI
    Engine : Diesel
    Year : 2010
    Mileage : 65k
    marky my 05 plate did exactly the same thing it came on at ignition and went off just after the EML. I was told that no fault ode was present and after about 20 or thirty starts the light went out all on its own.. The cars performance never waivered during the duration of the light being on during the start up sequence
    Northumberland
    Quote Originally Posted by marc7 View Post
    Not the spanner light mate. Should go off on 2nd click of ignition
    Northumberland
    Quote Originally Posted by goosey_1976 View Post
    Am going to wait til tomorrow and ring the dealers see what they say. The work is guaranteed for 12 months so hopefully not cost anything for them to read the code
    You're right, it's a stored fault code - not an active one. After a certain number of clean starts or 'x' amount of days the fault light will go out of its own accord.
    Northumberland
    Popped into dealers this morning and the plugged tech 2 in. It was a stored code for the glow plugs and he wiped it off....in and out in under 10 minutes
    Northumberland
    Aaaarrrgghh!! Spanner light back on now only on ignition again. Dealers need it booked it in to investigate. Why is coming back on only on the ignition when tech 2 machine cleared it? Surely if it was an active code it would be on with engine running?? Disconnected the battery today for an hour and the light is still on!!
  1. how to clear a spanner light fault
    By tonner in forum Electrical & ICE (including SatNav)
    Last Post: 12th November 2012, 21:50
  2. spanner and battery light on
    By honyin in forum Troubleshooting
    Last Post: 8th July 2012, 17:38
  3. Battery & Spanner Light on.
    By ickleric in forum Electrical & ICE (including SatNav)
    Last Post: 11th September 2011, 21:31
  4. Battery light and car with spanner icon?
    By johnnyallen in forum Electrical & ICE (including SatNav)
    Last Post: 22nd June 2010, 10:29
  5. Spanner light after changing battery
    By gtr1000 in forum Engine & Drivetrain
    Last Post: 10th December 2008, 21:40
