Results 1 to 10 of 15
Thread: turbo whooshing noise (not normal)
    south wales
    Default turbo whooshing noise (not normal)
    hi all my vec c 120 is making one hell of a whooosh noise at 2000 revs onwards until turbo stops spooling ive no black smoke from exhaust i dont feel the car has lost power but the noise sounds horenduss,
    ive looked under bonnet but cant see any split hoses, it sounds like pressurised air being pushed from somewhere but it must be after the turbo because of no lack of power
    anyone had this problem before?
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I had something similar on our 2.2DTi. It had a split hose down at the intercooler. VERY hard to spot
    Sounded like a Subaru Impreza
    EDIT: we did have a lot of smoke though...
    south wales
    confused
    im going to have a look now space is a bit tight in there though ill get back if i can see anything
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    egr pipe from turbo has failed on a couple and leaks under the manifold you'll need hepl to rev and search
    south wales
    ref celles, regarding split hose was it a top hose or bottom hose, ive checked all the top hose just 2 hoses left to check under intercooler, thanks for your reply,
    ref new post egr pipe, would i feel air leaking from that pipe even though the turbo isnt kicked in as the turbo only seems to spool under load and not in neutral, i will try this after the two other hoses i have to check
    all these are helping please keep these suggestions coming
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    well their shouldn't be any leaks at all good luck mate
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Quote Originally Posted by robshortman View Post
    Hey mate i got EXACTLY the same. If i'm right in saying it doesn't do it when you just rev only when you're flooring it in gear, clutch up? Have you done the airbox mod? I wondered if it was a sucking noise in relation to that? i was thinking of putting the pipe back on. Also i can't hear it with the windows up. With it being sunny i had the windows down, thats when i first heard it. It could have been doing it since i bought it in december TBH.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Bottom hose mate Follow the turbo outlet to intercooler and you should spot it
    south wales
    rolleyes
    Quote Originally Posted by BigWilko View Post
    hi big wilko thanks for your intrest, this noise is definatly not normal only started happening bout 2 weeks ago im now going to check the hoses celle mentioned, the sound is very loud and i must drive slowly past young kids because im scarred its going to suck them up and spit them out the exhaust, what is the air box mod? i havent heard of this one
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    From what i can understand the construction of the airbox is somewhat restrictive. Under the air filter is a removable bit of pipe. Unclip & remove it. This makes the airflow less restricted i.e. using the full panel rather than just 1/2 the filter. Winner. +2 or 3 bhp
  1. 16v cdti fuel gauge and whooshing noise under acceleration
    By paul080803 in forum Troubleshooting
    Last Post: 10th October 2012, 17:18
  2. vectra cdti 150 loud whistle/whooshing noise
    By sclarkson82 in forum Vectra C / Signum Car Chat
    Last Post: 18th June 2011, 00:51
  3. whooshing noise from a belt?
    By Dougb in forum Engine & Drivetrain
    Last Post: 27th March 2010, 10:38
  4. Whooshing noise above 2000rpm whilst driving in hot weather
    By marky2027 in forum Engine & Drivetrain
    Last Post: 26th August 2009, 22:02
  5. Whooshing noise
    By macane in forum Engine & Drivetrain
    Last Post: 5th January 2009, 22:17
turbo whoosh from signum 3.0 cdti
vectra c mild sucking sound on acceleration smoke
vauxhall insignia turbo sucking noise
insignia turbo noise
vauxhall imsignia whoosh when accelerating
