Thread: noise from rear suspension
    south wales
    Default noise from rear suspension
    my 1.9 cdti120 when normal driving even over a drain it sounds like the rear of the car is going to fall off, ive put it over the pit and everything looks fine no broken springs, no sign of oil from shockers and all bushes look good please help its bugging the s**t out of me
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Try grabbing a hold of the top of the wheel (when on the ground) and listen for a clunking sound, if you hear that then you need new upper control arms.
    Failing that it may be your arb bushes. They may look ok but they may still be the culprit hth
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    really yank on the top and lissen for the knocking
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Quote Originally Posted by mattv6diesel View Post
    Lol I missed that bit out, yeah give it a good tug
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    vectra's like to be touched
    south wales
    found a knock on the one side, i had the other 1 done a month ago, guess i should have had them done as a pair may as well do the arb bushes to cheers all
    Apr 2006
    Kingswinford
    Trim : LS
    Engine : 2.0 DTI
    Mileage : 150000
    I had exactly the same on the upper control arms. I gave both wheels a good old yank on the top and they both knocked. Both replaced this weekend, abit fiddly. The bushes on the hub end were like sponge, really soft. But all is good now..
    Theres an excellent how to on replacing the arms...
  1. Creaking noise from rear suspension...
    By Westy SRI in forum Suspension, Wheels & Brakes
    Last Post: 18th September 2013, 21:24
  2. Vectra C, 2002, Rear Suspension knocking/creeking noise
    By richardkay007 in forum Suspension, Wheels & Brakes
    Last Post: 11th May 2012, 19:05
  3. more rear suspension noise
    By robshortman in forum Suspension, Wheels & Brakes
    Last Post: 20th June 2010, 09:54
  4. Rear NS Suspension Noise???
    By l.brown23 in forum Suspension, Wheels & Brakes
    Last Post: 29th May 2010, 22:31
  5. Rear suspension knocking noise, help
    By clive3373 in forum General Chat
    Last Post: 8th May 2009, 20:24
