Results 1 to 3 of 3
Thread: new egr fitted but still spluttering plz HELP.
    Oct 2009
    wolverhampton
    Default new egr fitted but still spluttering plz HELP.
    HELLO PEOPLE PLZ HELP NEW EGR FITTED THURSDAY PICKED UP FROM STEALERS GOT HOME STILL SPLUTTERING BUT NOT AS BAD ONLY WHEN CHANGE GEAR 1ST 2ND GEAR IVE GOT THE 1.9CDTI O6 PLATE ANY IDEAS WELCOME CHEERS LADS, LASSES.... SIGNUM,,,,,
    Regular Member stevie1's Avatar
    Apr 2009
    CO DURHAM
    could be your inlet manifold m8 have a look to see if your control arm is still connected this is a good sign that it has failed if it is not connected, if you havent already checked this that is,hope this helps
    thats if its a cdti (150)
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Try cleaning the boost sensor!, then the throttle body, it wouldn't harm to whip the EGR off and check (if its the 150) to see that the hole in the inlet manifold where the EGR bolts on is clear, the Small hole always gets blocked!, then check to see if the 3rd injector has the modified plug ?, you will tell cos it will be a different color.
  1. FYI engine misfire / spluttering 3.2
    By DSmiddy in forum Engine & Drivetrain
    Last Post: 4th December 2013, 18:56
  2. My friends Vectra 1.9cdti 150 has a missfire and is spluttering
    By mattbrad30 in forum Engine & Drivetrain
    Last Post: 16th December 2012, 00:27
  3. Aux in fitted!
    By John LE in forum Electrical & ICE (including SatNav)
    Last Post: 1st August 2012, 22:57
  4. radiator fan and water spluttering from exhaust
    By TonyTangles in forum Troubleshooting
    Last Post: 6th March 2011, 20:51
  5. Fitted for 314mm discs but fitted with 304mm discs
    By Swatty in forum Vectra C / Signum Car Chat
    Last Post: 10th April 2008, 13:19
