Results 1 to 10 of 24
Thread: Correct oil for the Z32Se
    Regular Member 2.5 V6 Kadett's Avatar
    Jul 2009
    Heidelberg
    Default Correct oil for the Z32Se
    Hi
    What oil should I use in my motor its the z32se from the Vectra C ? Currently using Total QUARTZ 9000 5W-40 , the car seems to be using oil but it is not smoking at all so we are thinking that its because we are using the wrong oil . What is the normal oil consumption on these motors ?
    Thank You
    Full Member Big Sig's Avatar
    Mines running 5w30 but IMO 5w40 would be fine. Mine only uses oil if pushed hard, however all engines are different. Some use oil, some don't.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Try a different brand, maybe the GM 10w40 semi synthetic.
    Offtopic
    BigSig...are you from around Melksham?
    Jul 2009
    Heidelberg
    Was told it would use more oil when pused hard , I dont do that quite as often as I did . Just checked under the car seems to be some oil around the pulley of the sump , we had it off when we did the cam belt change . Had a leak on the front where the oil level warning sensor is , sealed that up and used a high heat grey silicon on the rest of the sump . Thinking that it might be the front crankshaft seal thats leaking maybe its just sweating. Will first try another brand like the GM one , just needed to know what oil will be safe for the motor .
    Thanks for the help guys
    Quote Originally Posted by Celes View Post
    Offtopic
    Yes, why do you ask???
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    we use mobil 1, 5w 30 in everything in our work shop level is the bigest worry
    Jul 2009
    Heidelberg
    Thanks , will see what I can get here . Just to make sure the z32se has a better oil cooler than the c25xe correct ?
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    i think they are identical but c25xe is well before me
    Jul 2009
    Heidelberg
    Was thinking that maybe the oil cooler is on its way out since there is like a brownish sediment in the coolant bottle . Read somewhere that the z32se had a steel oil cooler where as the c25xe had a aluminium one . There is no bubbles in the tank with the car running , and im fairly sure that if it was the oil cooler there would be a "mayo" like substance in the coolant bottle like I had when the c25xe cooler failed on me . Oil that was drained when we did the timing belt was black . So I dont think its the oil cooler thats causing me to loose oil .
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    think its updated alanv6 did one in his expolice the other week
  1. z32se Clutch Kit.
    By Vectra_C_Chris in forum Petrol Engine related
    Last Post: 16th April 2011, 15:29
  2. Z32se Pre cat
    By Leigh16v in forum Tuning
    Last Post: 26th January 2010, 21:50
  3. z32se history
    By big_dave in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2009, 08:41
  4. z32se tuning
    By Twiggy in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2007, 10:35
z32se sump leaking
correct oil for z32se
z32se timing belt replacement
vectra c oil leak z32se
z32se oil consumpsion
vectra number 2 oil is 32
z32se oil capacity
z32se oil grade
z32se vectra timing belt change
vectra c z32se hard start when hot
z32se oil
z32se recommended oil
