Results 1 to 3 of 3
Thread: would a
    Beds
    Default would a
    cd 30 with gid taken from a pre facelift fit a facelift and work with the steering controls and trip computer?
    Mar 2007
    North East
    If it was in a prefacelift then it's a full can version, some did exist just prior to the change to facelift so yes it should work.
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Yes it will!!
    ALL CD30's are Full Canbus, regardless of being pre-facelift or facelift.
    The only differences between pre-facelift and facelift is the size of the Colour Info Display....wider in the facelift vehicles!!
    If the radio and screen are still paired, then it will be merely plug and play...ish.
    Just check that you have 2 reds and 2 browns in the display plug.
    If not, then you need to
    link pin1 to pin 2 and then
    link pin 3 to pin 5....job done.!
    Extra answers - wheel controls - yes these will work
    BC / Computer functions - Yes if they were working in the donor car. (The settings will remain unchanged within the display EEPROM)
