Results 1 to 10 of 16
Thread: Cambelt noise
    salisbury
    Default Cambelt noise
    After investigating and replaceing what i thought was a noisy alternator roller turns out to be coming from the cambelt area the noise is a whoosing which disapears when engine is warm, when i sprayed a small squirt of wd ( i know not a good idea to spray wd any where near the cambelt but it was a mineut squirt ) on the roller directly under the cam wheel the noise stopped. My question is, is this just a sign the belt and rollers need changing and if so is it worth doing the water pump at the same time.
    Signum 1.9cdti 150ps 2006 63,000 miles.
    west yorkshire
    i thought it was
    every 3 years or 100k, acording to the book any way
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    imho i would always change the pump when doing the cam belt kit as the pump is only about £40.00 extra to buy and while it's in bit's it's easy to change...learn't the hard way years ago on my 16v astra cam belt kit £330.00 2 week's later water pump and cam belt kit £380.00
    Midlands Mod Shop - NFFC.
    5 Post(s)
    Quote Originally Posted by tony stoney View Post
    i thought it was
    Which book is that?
    The official recommendation is 100,000 miles OR 10 years (whichever comes sooner) for the Z19DT & DTH engine (2006 onwards).
    Regular Member slipperysam1984's Avatar
    Apr 2009
    Bournemouth
    Which book is that?
    2005 Onwards. Z19DT
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    5 Post(s)
    Trim : GSi
    Mileage : 190,000
    Could be a cambelt tensioner, if that's where you squirted the WD40. If it were me and I had the money, I'd get it replaced or do it myself. If the tensioner fails and seizes up, the belt will fail in seconds and you know the rest...
    But I am not certain that I've understood your original post correctly.
    Paul
    2003 Vauxhall Vectra GSi 3.2 V6
    salisbury
    I have found a pic from one of the how 2's and have put a red circle where i sprayed the wd40 on the flat side of the belt not the toothed. it seemed to stop the noise......for a bit! any ideas?
    salisbury
    no pic so lets try again!!
    5 Post(s)
    Trim : GSi
    Mileage : 190,000
    Sorry, buddy. I'd have to defer to someone else's wisdom on this one. I am no expert on timing belts. I had a garage do my GSi for me. Next time, though, I shall do it myself.
    I really do hope that you get to the bottom of the problem, though.
    Paul
    Regular Member DaveW555's Avatar
    Cannock
    If it was mine I'd be changing the lot, any noise from that area is not good, I've had water pumps collapse on both the Z19DT and Z19DTH engine and that would throw the timing out and bend valves etc. If you're handy with the spanners you could easily do it yourself in a couple of hours. The way I look at it is its better to spend a couple of hundred quid on a new belt kit and waterpump (I believe they now do a kit with the waterpump in) and fitting (if you're unable to do it yourself) than spending 5-600 if the pump collapses or the tensioner fails or the belt snaps.
  1. Replies: 3
    Last Post: 8th September 2012, 12:13
  2. Clackerty noise from cambelt cover
    By Giw in forum Engine & Drivetrain
    Last Post: 7th July 2012, 21:05
  3. Wheel Alignent or New Tyres? Noise Noise Noise
    By lostdog in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 13:29
  4. Noise on startup from cambelt side
    By cookie in forum Engine & Drivetrain
    Last Post: 9th November 2007, 12:31
  5. 1 noise solved (front Bearing) + 1 new noise (squeaking front brakes!!!)
    By joseantoniovalle in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 08:54
vauxhall 3.2 v6 startup sound
vectra cdti cambelt pulley noise
