Thread: Another thread from me, this time about the intercooler....
    Regular Member PAULMAC77's Avatar
    warrington
    Default Another thread from me, this time about the intercooler....
    ok, so i got my car on the ramp in work today to have a look at the boost pipe?? on the os of the engine as you look at it. Once o got it in first thing i noticed was that the 2 securing brackets on this pipe had no bolts in so it wasnt actuallt attatched to anything other than the inlet manifold at the top and the intercooler at the bottom. So i but 2 new bolts in so its now secure, now here's that bad part, along the bottom of the intercooler is a build up of oil the mechanic who looked at it with me said the corners had also swollen and gone a little out of shape. I have no fault codes in the car as i scanned it. The swilr rod has stayed in place after a drive today so fingers crossed that will last a while longer, i also took the boost pressure sensor off and give it a good clean, and also i decided to take off the dtuk box and see how it runs with out that on for a few weeks, so far so good today, missing the little extra power but if it means it runs better then its better for me. I priced an intercooler up this morning and it was about £130, what kind of job is it to do? does it slide out from in between the condensor and the radiator or do all 3 units have to come out together?? think im going to try cleaning the egr valve next weekend see if that helps my probllems of the slight missfire when 1st started and lack of power sometimes in the early rev range..
    warrington
    No one done an intercooler then? Never mind...
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    plasma has fitted a bigger front mounted intercooler to his show car, best pm him about it mate
    hth
    Midlands Mod Shop - NFFC.
    Regular Member Vectra Meldrew's Avatar
    Hertfordshire
    I fitted an intercooler a couple of weeks ago. Not a bad job really. All under-trays come off, bumper off (just a few screws - I was looking for some heavy bolts!) bottom radiator mounts off then just a few fiddly torx bolts holding the 3 rads in place. Once all are loose the intercooler can be carefully dropped down between the two rads. I had to bend the metal tag holding the aircon rad on the drivers side but its really soft metal and bends back ok. Its a bit tricky getting all three back on the mountings together but not too bad really.
    Good luck.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    you do it from the front take the bumper then the a/c rad and then take the intercooler out the front
  1. Replies: 117
    Last Post: 8th November 2012, 15:03
  2. Standard intercooler v front mount intercooler
    By tommytonguedj in forum Engine & Drivetrain
    Last Post: 29th June 2011, 09:58
  3. Real time weather thread all regions.
    By Robward27 in forum General Chat
    Last Post: 8th February 2007, 21:29
  4. Bring back the Krays (thread split from scam thread)
    By VauxVeteran in forum General Chat
    Last Post: 26th July 2006, 09:58
