Thread: change gearbox oil on auto signum
    Regular Member signum03's Avatar
    worthing
    confused change gearbox oil on auto signum
    evening all, did ask this question a few months ago and didnt really gt anywhere, anyway i have a 2003 3.0 v6 signum auto y30dt engine, and would like to change the gearbox oil, has anyone done this on this model? would like a how 2 but doesnt seem to be one any ideas??? thanks in advance.
    I would advise that you look in the Haynes manual (Vectra one would do) for the procedure required to change the fluid in the AF40 autobox as its quite a complicated job.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    That'll be an AF33 in an 03 plate not an AF40
    I'd suggest you get it done by a specialist...not a cheap game if the gearbox goes
    Quote Originally Posted by Celes View Post
    I never noticed the year, ill get my jacket now. LOL
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by Rapala View Post
    Apparently the AF40 box is much more difficult to handle if you want to replace the fluids. That's why I pointed out the difference
    worthing
    i have a haynes manual, they never made one for the signum so its a vectra one, and guess what it doesnt coner the y30dt engines so im stuck!
    The Vectra 02-55 reg Haynes book does cover the draining and refilling of the AF33 and AF40 autoboxes though. Section 7b2.
    Jun 2006
    Kirkintilloch, Scotland
    Default Refilling AF23 auto box
    My vehicle has the AF23 auto box and it was my intention to replace the oil later this month.
    Reading the Haynes manual it appears relatively straight forward but the suggestion from some of the entries in this thread suggest otherwise.
    Is there perhaps some difficulty in releasing the "selector cable end fitting" ? The manual states "using a suitable forked tool". Does it require a special tool?
    If so what kind of thing is it?
    Is there any other step that is likely to cause difficulty?
    Thanks,
    Dave
    worthing
    just read that chapter but there is no mention of changing the gearbox oil filter???
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    you cant change the filter is a complete strip and rebuild of the gearbox to do this i know stupid design but thats the japs for you (gearbox is made by aisin warner so is japanese)
    i didnt have to remove any selector you will however need around 8-10 litres of oil as its a multiple part drain and flush the oil you need is type 4 atf and is quite expensive comma make one and call it asw (must be this oil or wont work properly)
    release the drain plug underneath to drain the fluid probably only 2-3 litres i then replaced it and refilled through the sensor hole on the top as it saved removing anything other than 1 bolt check the level using the dipstick with the engine running in park once level correct leave running for 5 mins take for a quick spin (3 miles ish mixed driving) repeat this process around 3 times.
    reason for this is the box just wont release the oil properly and like i said its kind of a flush fill process.
    HTH
  1. Auto Gearbox Fluid Change
    By Homer in forum Engine & Drivetrain
    Last Post: 15th November 2012, 10:50
  2. Auto Gearbox Oil Change
    By rocket999 in forum Engine & Drivetrain
    Last Post: 22nd June 2011, 19:46
  3. Auto Gearbox Oil Change -Special Oil?
    Last Post: 28th July 2010, 18:59
  4. 3.2 auto gearbox oil change
    By gtr1000 in forum Engine & Drivetrain
    Last Post: 2nd March 2008, 12:48
  5. Auto gearbox oil change
    By Elevonic in forum Engine & Drivetrain
    Last Post: 28th August 2007, 12:45
where is drain plug on signum auto gearbox
opel vectra c gearbox oil filter
signum 3.2 automatic transmission oil
vauxhall signum automatic gearbox oil change
vectra c 3.0 cdti oil transmission manual
vauxhall automatic gearbox oil change
signum transmission oil
3.2 liter engine automatic opel signum gearbox oil
how to change oil in an automatic vectra
does a Vauxhall signum 2007 have a gear box filter
what is the transmission capacity on a Vauxhall signum 3.0 v6 auto gearbox
