Thread: Eml on
    salisbury
    Default Eml on
    I have just been changing a roller on the alternator belt to try and eliminate an annoying noise when cold, this has reduced it but after further investigation another noise was coming from the cambelt rollers, I had to start the car with out the air box on to be able to trace the second noise and i now have the eml light on, is this due to no airbox or maf meter connected and if so will it go away on its own.
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    yes it because of no MAF unplug the ecu for 10 mins and reconnect should knock the light off
    salisbury
    where is the ecu?
    Apr 2008
    Wigan
    under the bonnet! lol sorry pal without knowing what engine i wouldnt like to guess have a look under the bonnet its usually square metal with 2 plugs on it mines a 1.8 and its on the top of the engine
