Thread: load index help?
    Regular Member AKeeNShoT's Avatar
    South Shields, T&W
    Default load index help?
    the alloys i'm trying on the car at the moment are wrapped in nankang ns1's @ 215/45 r 17 87v, i need to know if that load rating is too low, its a 2.0 dti estate, is the load index per corner ie 545kg for each corner. these wheels have come off an omega if that helps,
    thanks in advance,
    michael
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    they should be ok what does you old wheels/ tyres say
    South Shields, T&W
    fronts 91w, rear 97v
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    Factory fit 18 inch Bridgestone run 95 side load. 19 inch Contis run 91 side load. Not sure on 17 inch NCT 5's. I was advised by both Goodyear and Michelin not to run 87Y on my 19's as it was below what Vauxhall originally specified and may not be safe.
    Like you say, 545Kg per corner for 87 loading. Veccys are around 1500Kg model dependant. Then you have to consider passengers, fuel and extra load in boot. Then the increased load on one corner which would increase quite dispreportionatly if you break heavilly into a corner.
    Regular Member no1golfer's Avatar
    Jul 2009
    newcastle upon tyne
    my 17s are 95 load,not sure if there original though.
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    I just looked on Mytyres and the 215/50R17 is a 91 load index. If that is factory fit I would not advise anything less based on 19's having 91 and 18's having 95.
    South Shields, T&W
    and 17's? that index is for a car over 2 tons corner to corner is it not? i'm no expert, but i dont think my car will ever be that heavy
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    I'm thinking these figures may take into account the loads when the car is driven at speed. Also not having the correct load spcified by the manufacturer may invaditate your insurance.
  1. tyre load index
    By starykokot in forum Suspension, Wheels & Brakes
    Last Post: 10th October 2011, 21:26
  2. is Load Index: 91 ok for 1.9 vectra?
    By amir2300 in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2011, 12:44
  3. Tyre load index
    By Roadhog in forum Handling & Braking
    Last Post: 28th April 2009, 09:53
  4. 2 Good Year - Eagle F1 GS-D3 235/35/19Z - 91 Load Index
    By Mark The Cabby in forum Parts for sale
    Last Post: 16th January 2007, 18:24
