Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Wont go past 3000rpm
    Jun 2009
    Castleford
    Default Wont go past 3000rpm
    I have a 2004 Signum 3.0dti V6. The car will not go above 3000rpm and when you reach this it begins to jerk and misfire. Happy enough below this point.
    Diagnostics check brought back no faults. EGR has been stripped and cleaned did not make an ounce of difference. My mechanic is now baffled. Any advice welcome...........
    salisbury
    is your throttle butterly valve opening completly, may be stuck or restricted or have you checked your fuel filter may be fuel starvation.
    Full Member Big Sig's Avatar
    Sounds like a fuel problem to me.
    Hope I am wrong - have a look here - http://www.vectra-c.com/forum/showthread.php?t=108360
    Get it on tech 2 and ask them to look at the fuel demand vrs supply.
    Jun 2009
    Castleford
    Whats tech 2?
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Replace the fuel filter. If that won't help you're looking at a SCVs replacement.
    Main dealer level equipment that can see a lot more than just fault codes.
    Jun 2009
    Castleford
    If you give the car a good hideing for example drop it down the gears to make it work. It does sometimes come to life and begin to work. Then as soon as the car slows you go through the same sceneario. Taking this into account would you still point at the fuel pump and 'scvs'. I really dont fancy these at all!!!!
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Mine was the same mate...but before looking at expensive repair bills replace the fuel filter It can do wonders.
    Do what Celes suggest first
    Jun 2009
    Castleford
    Fuel filter is ok and Tech 2 test says the fuel demand vrs supply is fine.............
  1. Wont rev over 3000rpm
    By RVESRS in forum Engine & Drivetrain
    Last Post: 5th July 2012, 12:52
  2. Wont rev past 2500, no power
    By silvershadow in forum Engine & Drivetrain
    Last Post: 7th March 2012, 11:16
  3. My cdti keeps cutting out as soon as i past 3000rpm exactly??
    By richiem in forum Engine & Drivetrain
    Last Post: 21st June 2011, 09:41
  4. Vectr C wont rev past 2500
    By Rallyingden in forum Engine & Drivetrain
    Last Post: 13th March 2011, 12:59
  5. 3.2 v6 wont go past 4k
    By crash112211 in forum Engine & Drivetrain
    Last Post: 18th January 2010, 13:31
vectra wint go over 3000 rpm
vectra rpm wont go over 3000 site:www.vectra-c.com
vectra wont rev over 3000 rpm
