Thread: wheel settings
    doncaster
    Default wheel settings
    can anyone tell me what the correct settings are for the front and back wheels for correct alignment so you dont get inner wear,or choppy tyres.i.e toed in minus or positive offset or toed out ,there is a lot of confusion about what the correct settings are ,help required to clear this matter up.if i rang vauxhall up will they tell me ,i have a 1.9 cdti 150.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    SRi = sports suspension so here you are. http://www.vectra-c.com/forum/showpo...51&postcount=3
    Ride height is measured from the centre of the wheel to the highest part of the wheel arch.
    doncaster
    mine is a 1.9 cdti design not a sri will that make any difference to the way it is tracked.it says on the settings and it says saloon,saloon sports,estate.they have been setting mine up on normal vectra c std will this make a big difference has it has been back 3 times now and it is still right hand down and pulling slightly to the left ,it will have to go back again ,what a pain in the btm.help needed on what difference sports and std would make,thanks
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    The ride height is the determining factor and as you can see from the alignment data, the camber angles change with the ride height.
    Also have a read of the techy stuff here http://www.wheels-inmotion.co.uk/index.php so at least when you take it back you'll at least be able to tell the muppets what's expected. If they don't understand global geometry theory, go elsewhere.
    Glasgow
    If its a design then its just standard suspension.
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    Looking at the above link with settings. I see there is 3 trim levels, standard, sport and bumpy road. Some ride heights have 1 setting, others 2 and others 3. If theres 1 does it apply to all? If theres 3 then the 3 settings in order for each? But when only 2 settings, then what??
  1. four wheel alignment settings
    By tights in forum Suspension, Wheels & Brakes
    Last Post: 7th March 2011, 21:21
  2. wheel nut torque settings
    By jon ixi in forum Suspension, Wheels & Brakes
    Last Post: 4th January 2011, 19:10
  3. Torque settings for fly wheel bolts?
    By jimjam in forum Engine & Drivetrain
    Last Post: 18th September 2010, 22:39
  4. NAT settings
    By Guyver1 in forum Games Room
    Last Post: 26th March 2009, 11:36
  5. FWIW - Wheel alignment settings - Signum MY 06
    By omega2498 in forum Suspension, Wheels & Brakes
    Last Post: 3rd December 2006, 00:58
