Results 1 to 10 of 16
Thread: 2dti vec b
    Regular Member SRimonkey's Avatar
    wednesfield
    Default 2dti vec b
    father in laws car just died an been towed by the aa.........only thing i`ve been half told is fuel module and 1000 pound to fix.......whats happened to it lads???
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    be the ecu on the fuel pump from the sound of it unfortunatly that price sounds quite cheap try a local diesel spec he might be able to sort a recon pump
    Regular Member suggs1971's Avatar
    east cleveland
    Sounds like fuel pump as they are expensive, but i did a search on the net and there are specialist companys who recondition your old pump, prices were £250 - £300 still alot of money but not as bad as a new one for £1500.
    wednesfield
    can another one be used from a donor car or is that a pain?
    Apr 2008
    Wigan
    only if divorced via tech 2 properly will then need to be recoded i think if its me i would look at a £300 repair
    wednesfield
    an that can be done as repair including that ecu part?
    east cleveland
    One of the companys i found on the net said if you remove the ecu from the pump, (they do a how 2) and send it off to them they charge £35.00 to check the ecu, if found to be faulty they knock the £35.00 off the total price for reconditioning. I think they say its a 2 - 3 day turn around. They also show you how to refit the ecu. I'll see if i can find the company for you.
    wednesfield
    cheers bud
    Devon
    76 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Irmscher Insignia CDTI 130
    east cleveland
    Yep there the ones i found bigmac, i was chuffed when i found companys who do repairs of the fuel pump.
  1. 2.2Dti
    By Gazz in forum Diesel Engine related
    Last Post: 24th May 2011, 12:44
  2. Will this fit my 2.2dti
    By sberrow in forum Vectra C / Signum Car Chat
    Last Post: 5th May 2011, 20:25
  3. Eml 2.2dti
    By Gortreck in forum Engine & Drivetrain
    Last Post: 3rd March 2010, 20:23
  4. its not too bad for a std 2.2dti.............
    By david.aka.judas in forum Gallery
    Last Post: 16th March 2009, 08:58
  5. 2.2dti, not GM?
    By prm in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2007, 00:32
