Thread: Drivers door module fuse!!!
    Nov 2007
    Fife
    Default Drivers door module fuse!!!
    Hi, can anyone shed some light on a problem I am having. I have no power in my drivers door, I cant put down the window, operate the mirrors, lock the door remotely etc etc.
    I checked the fuse for the door module and it was blown, therefore, I replaced it. However, the minute I use anything electrical on the door, the fuse blows again
    I am fine with cars mechanically, however, anything electrical, I am not so good with.
    Has anyone had similar problems, if so, how do I rectify it. I would appreciate any help I can get.
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    sounds like a short in the door wiring i would haste a guess it within the flexi harness between the door and the main body try removing the plug and having a look for anything obvious
    Dunstable
    sounds like a loose wire or a wire with damaged insulation and making a short on the body / door when you use something. Does it blow the fuse when you just use anything on that door. I'm guessing it's ok when you lock / unlock it. Does it just blow the fuse when you open the window or something?
    Oct 2010
    south shields
    hi i know its a while since this thread but im having exactly the same problem!!! how do i check the fuse on the door module please? desperately need this fixed im lost without my window!
    giltbrook
    Did you get this sorted?
  1. drivers door module
    By mauricemersey in forum Electrical & ICE (including SatNav)
    Last Post: 17th December 2012, 18:30
  2. For Sale: Blue LED Drivers Door Module
    By Envy in forum Parts for sale
    Last Post: 9th November 2012, 21:46
  3. Drivers Door Module
    Last Post: 17th August 2009, 17:27
vauxhall vectra c drivers door fuse
vectra drivers door module fuse
