Doe Anyone Know If There Are Any Problems Changing The Silver Headlights On My 1.8 Elegance For The Smoked Ones Fitted To The Sri Model
Thanks In Advance![]()
I would guess that it's just a straight swap.
I'm sure someone will be along shortly to correct me if I'm wrong.
Thanks Just Need To Know If It Is Just A Straight Swap Before I lash Out Lots Of Money
Should be a straight swap... the only difference is the internal frame colour.
Thanks Looks Good So Far. Sorry To Go On But Does The Bumper Have To Come Off And If So Can Someone Give Me Some Ideas On Removal, Thanks For Your Patience.![]()
Yes it does.... look in the How-2's section
As Above....bumper Needs To Come Off, And Lights Are Just A Straight Swap...ive Done It..looks A Lot Better..helped That I Was Fitting The The New Front Bumper At The Time. Made It More Worthwhile. Mines Is Just An Ls Model. Looks Better With The Washers In The Bumper Too, But Mines Arent Plumbed In Yet..
I have the plumbing parts sat here in my garage!!!
Cars Up For Sale Though.....so,think Ill Leave It To The Next Owner...if I Cant Get Rid, Ill Get Back To You..cheers
Originally Posted by Bethan39
Only come across this thread as I have just ordered a set of the smoked headlamps today and was searching around for other relevant threads!!Originally Posted by Bethan39
It's a straightforward straight swap for your existing ones. Remove bumper to allow access to each lamp (3 x Torx screws under wheel arch and one fixing plug on the bumper next to headlight), unscrew three bolts on headlamp, pull out and remove wiring harness plug from back. Then reverse to fit them.
You will more than likely need to get the new headlamps realigned.
I should be doing mine next week!
