Results 1 to 10 of 13
Thread: I think its tramming?
    Oct 2009
    worcestershire
    Default I think its tramming?
    Hi chaps
    my gsi gets a bit squirmy over rough surfaces and if its not an even surface under braking it does the same.it can be under power or not,however on a reasonable road ite fine,tracks and no pulling also cats eyes it can also do it a little.The tyres are kumhos and the cars done 80k.Would new upgraded shockers sort it or are they all a bit like that?
    cheers
    P
    Regular Member crespo's Avatar
    Bournemouth
    Check your tyre pressure.
    Regular Member booker413's Avatar
    West sussex
    Could be your shocks had the same on my golf, well the rear ones. Put updated ones all round, problem sorted, best of luck mate, adam
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    what size tyres and wheels you running fella
    Oct 2009
    worcestershire
    standard wheels are tyres and pressures standard too!
    p
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    i had the same problem. At M.O.T was advised shockers needed changing all round, got them all changed, felt like a different car. Problem solved. Was not cheap about £300 in total.
    3.2 v6 Signum and loving it
    Oct 2009
    worcestershire
    Quote Originally Posted by Johnsdutton View Post
    were the new ones upgraded or standard
    P
    West
    can you feel any play in the steering, it may be woth having the inner track rods looked at also... £25 each ish
    hth
    Oct 2009
    worcestershire
    hth
    no its spot on
    P
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Quote Originally Posted by jvr View Post
    P
    Bilsteins from Eurocarparts.co.uk
