Results 1 to 10 of 14
Thread: PARROT MKi9100 - NO POWER HELP
    Kent
    Default PARROT MKi9100 - NO POWER HELP
    I bought a Parrot MKi9100 kit for my Vectra. Installed it last weekend, using one of those converter cables which has the ISO connectors on. Plugged it all in, but there is no power to the Parrot.
    My question is, even though you are using the ISO converter leads, do you still need to wire the red power, orange power and the earth manually somewhere else, or does it take it's power from the ISO lead? I assumed that it did take it's power from the converter lead. All fuses are OK, and the converter lead does have two fuse holders with fuses in, so am I being stupid or is there something more sinister?
    It's connected to my CD70 NAV.
    Also where is the best place to put all the wires. I guessed probably in the small area to the left of the centre console next to the head unit, between the head unit area and the glovebox. Where has anyone else put the mountain of wires?
    Hope some of you out there can help me.
    Thanks in advance.
    Regular Member markm's Avatar
    Oct 2006
    Portsmouth
    The Quad lock to ISO leads do not offer an ING feed on the Vectra,Astra or Zafira, you'll need to pull that off the car somewhere, behind the glove box there is a bunch of cable's, there are a few blacks in there which will give ignition,
    Once you've done that is should be fine mate
    Regular Member russ1969's Avatar
    Worthing
    I took mine from the fag lighter
    Kent
    Cheers guys, just been reading another Parrot kit fitting instruction on this forum, says just what you guys say.
    Thanks a million, will give it another go at the weekend. Looks like my gues of place to put the control box and the wires was right too. I didn't take the glove box out before, so it was very awkward. Thanks again!!
    I got a parrot fitted the other day too my vectra, and they used the wire off the fag lighter as said before.
    Jan 2008
    Lincs
    Vehicle : Vectra C Hatch
    Trim : Exclusive Plus Pack
    Engine : 1.9 CDTi Z19DTH
    Year : 57
    Mileage : 100k+
    There's a blue wire on the SOT lead that is the one to connect to a switched live. The red and orange leads need to be swapped at the fuse holders.
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    how have people joined the wires together to make the ign live?
    Kent
    Haven't been brave enough to try again yet, will do so this weekend. So do you need to run all three wires, switched live, permanent live and earth?
    Admin plasma's Avatar
    On the Forum
    271 Post(s)
    Engine : 150
    Mileage : 74000
    I wired mine in the other week to make it all work properly. Took the feed off the ciggy lighter and used the dreaded 'scotch lock' connector for it... the rest of the wires were left as normal...
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Kent
    Stumbling block straight away. I can't figure out how to get the glovebox out. I've removed the three torx screws at the top, but can't figure out how to get it out after that, can't see any more screws. I thought I could just drop down the actual tray bit, and then remove it completely. Help!!!
  1. Parrot MKi9100 are they easy to fit ?
    By big nath in forum Electrical & ICE (including SatNav)
    Last Post: 29th July 2011, 12:00
  2. Parrot MKi9100
    By Homer in forum Electrical & ICE (including SatNav)
    Last Post: 10th July 2011, 18:10
  3. Parrot Mki9100 & Center speaker
    By iani in forum Electrical & ICE (including SatNav)
    Last Post: 5th May 2011, 20:13
  4. Parrot Mki9100
    By johnynoi in forum Electrical & ICE (including SatNav)
    Last Post: 1st July 2009, 21:44
parrot mki9100 no power
parrot vectra center speaker
vectra c parrot wiring
