Results 1 to 2 of 2
Thread: vectra c 1.9cdti problems.
    wolverhampton
    confused vectra c 1.9cdti problems.
    hi guys just wondered if anyone could help.
    Ive been having a few little probs latley that i need help with.
    first one. can anybody tell me why my headlight adjuster doesnt work anymore. checked the fuses i think and i carnt see why they have stopped working.
    Secound thing. im gettin a nocking sound from my rear wheels. when i jack the car up i can rock the wheel in and out very slightley. can someone tell me what i need replacing to stop this. My vectra is lowered on eibachs and i was told it might be the dampers goin. my car has done 38000 miles. one last thing. Does anybody no if i replace the dampers will it make my vectra any lower at the back because at the moment its alot higher than the front and i would like it abit lower. if not what rear springs can i by to do this. Bit of a long winded request but if anybody could help i would be most greatfull. Oh yeh i forgot. does anybody no where i can get my swirl valves replaced because that silly rods come off and ive been told ive gotta have a whole new manifold with swirls. or shall i just leave it and if i do what problems will i get. Thanks again
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Never come across the headlight problem myself so (no pun intended) i cant shed any light on that one!, knocking on the rear sounds either rear wheel bearing or rear arm bushes some are common for going on the rear!, the size of the spring dictates the ride height so someone may be able to recommend a make suitable for lowering (pics of your car would give a guide), as far as the swirl bar goes there's a fix for a £1, in the .how to section', this isn't a permanent fix but can last for a couple of years as mine did, or if the manifold is sourced via ebay along with a vx gasket iit can be replaced for £185 diy!.
  1. 05 1.9CDTI Sri (120) Clutch problems
    By Casey in forum Engine & Drivetrain
    Last Post: 27th November 2011, 12:24
  2. problems with 1.9Cdti 120
    By Kevinw29 in forum Engine & Drivetrain
    Last Post: 5th September 2011, 09:24
  3. Vectra 1.9cdti starting problems
    By Dale1 in forum Engine & Drivetrain
    Last Post: 20th June 2011, 14:29
  4. Vectra C 1.9cdti problems
    By collieq in forum Engine & Drivetrain
    Last Post: 5th February 2010, 01:56
  5. Power problems on my 1.9CDti (120)
    By RedLine in forum Engine & Drivetrain
    Last Post: 26th July 2008, 22:21
