Results 1 to 10 of 17
Thread: vx vhc and problems found
    Regular Member denzilbud's Avatar
    cambridge
    Default vx vhc and problems found
    took my car to vx to have it put onto their diagnostics and came back with no communication with cim ipc,vehicle speed signal,range and performance,can-bus ecu message range performance abs,right speed sensor incorrect signal,but whilst they were there they done a vhc and they came back with rear control arms,broken coil spring,and rear springs corroded,so rear control arms and lowering springs are gonna be orderd but what i want to know is if anyone can shed any light on the diagnostic side of things the bloke mentioned that to fix the problem they would need to re wire the plug on the abs pump ive been reading other posts and i dont have any of the other syptoms ie indicators or any cim related issues
    cambridge
    anyone
    Full Member Big Sig's Avatar
    Have you removed and cleaned the abs plug? Works well for some members with similar issues.
    cambridge
    thats what ive been reading as well.is it just a case of unplugging it as i didnt want to cause any more problems
    cambridge
    can anyone advise
    Administrator plasma's Avatar
    On the Forum
    368 Post(s)
    Engine : 150
    Mileage : 74000
    Disconnect battery, get some contact cleaner, spray into the plug, let it dry/evaporate, then reconnected plug, then reconnect battery
    cambridge
    cheers plasma will i need any codes for radio and car pass also should i disconnect the +or -
    On the Forum
    368 Post(s)
    Engine : 150
    Mileage : 74000
    yes, for a 52plate you'll need your radio code... diconnect the negative side of the battery
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    You'll also need to re program windows mate. Hold down until you hear a beep/tick then all the way up till the beep again.
    cambridge
    cheers rushy
  1. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  2. 1.8 vvti problems, problems problems!!!
    By gstore in forum Petrol Engine related
    Last Post: 3rd March 2012, 01:31
  3. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  4. Another couple of problems I've found
    By Adz86 in forum Vectra C / Signum Car Chat
    Last Post: 7th October 2009, 10:29
  5. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
