Thread: Random Spanner Light
    Brighouse
    Default Random Spanner Light
    I am getting a random spanner light on my CDTi 150. It has just started appearing after ignition and then turns off after 5 minutes.
    Also, if I turn the car off and then restart - it does not appear second time around. Any suggestions?
    TIA
    Martin
    Regular Member corderz's Avatar
    Bradford
    I have the same light on my 3.2, think mine is summat to do with an immobiliser fault, going to take the battery off for a bit to see if it takes it off. In the diesels i think its something to do with water in the oil filter? Not too sure though, have u done the self diagnostic on it?
    Regular Member sdnatlst's Avatar
    Nov 2009
    Cambridgeshire
    service is due...
    Regular Member tramman's Avatar
    Selby, North Yorkshire
    Is it the car with the spanner through it? If so and it goes out the manual says not to worry about it, if it stays on there is a bigger problem.
    I'm only guessing as mine is doing the same thing and I have had it on my Tech 2, but I believe the fault you will find is due to the glow plugs and they will require changing. The reason it doesn't come on the second time around is that the engine is warm.
    If you are over towards Selby at all, drop me a PM and I can hook up my Tech 2 and confirm the fault.
    Brighouse
    Cheers for that. I work in Leeds so if I can get over towards Selby I will pm.
    Martin
    Brighouse
    I've just read about the water/oil fliter thing and I tried the self diagnostic things too - but couldn't get it to work!
    Not overly concerend unless it stays on all the time. Also not due for service for another 4,000 miles.
    Quote Originally Posted by corderz View Post
    Bradford
    whip the battery off, it will be reet!
    11 Post(s)
    Quote Originally Posted by sdnatlst View Post
    service is due...
    I don't know how many times it's been mentioned on here but the car/spanner light IS NOT the service reminder light.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. random warning light
    By Allenglish2003 in forum Engine & Drivetrain
    Last Post: 18th August 2012, 17:41
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. Random Brake light Warning
    By gdansk in forum Vectra C / Signum Car Chat
    Last Post: 5th May 2010, 11:34
  5. Random Spanner light
    By dazza-diesel in forum Engine & Drivetrain
    Last Post: 28th June 2008, 21:55
