Thread: Can,t get rear door hadles to work
    Norwich
    Trim : SXi
    Engine : 2.2
    Default Can,t get rear door hadles to work
    Took the read door handles off to respray them again and this time they will not play ball.
    I,m winding the screw all the way back, fixing the stubby part, putting the door handle in place, winding the screw back up and the handle will not locate or fall back into place. What am I doing wrong?
    Norwich
    Trim : SXi
    Engine : 2.2
    Stripped both doors down made sure cables connected, and pins all ok, doors handles sit flush when you pull them to open nothing happens yet open from inside fine.
    Really fed up now as been stripping these damn doors all afternoon for jack squat
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    are you sure the "bar" that connects to the bracket from the inside havnt come off? (does the handel go in by it self or stay out?)
    Norwich
    Trim : SXi
    Engine : 2.2
    I checked the bar and even removed it to check the function and reconnected it. The handle goes in by itself but when you pull the handle it moves away from the door how it should but thats it. Does not open the door and its both sides on the rear front works fine!
    Engine : 2.2 Direct
    it then sounds like you havnt turned the bolt/screw all the way in..
    Norwich
    Trim : SXi
    Engine : 2.2
    I,ve screwed it all the way in otherwise the handle would not sit down and you would be able to pull the small stubby part out.
    I,ve spent 5 hours taking the door cards out, the locking mech, checking handles and I,m stumped. I,ve wound the screws in and out, taken the handles off a million times thrown them 2 million times and now I have a car with doors that do not open from the outside.
    I must be missing something as its only the rear doors and why both of them?
    Norwich
    Trim : SXi
    Engine : 2.2
    So no one has ever had this problem? Ah well a trip to the stealers then I suspose
  1. rear ashtray , do they ever work ?
    By biffbangpow in forum Bodywork & Interior
    Last Post: 16th September 2012, 10:39
  2. Passanger and rear electrical windows don't work
    By matt89 in forum Electrical & ICE (including SatNav)
    Last Post: 11th August 2012, 19:55
  3. Will it fit and work? Rear air vents
    By Envy in forum Styling
    Last Post: 6th April 2012, 09:36
  4. eletric rear door some time not work prperly
    By msqualo in forum Electrical & ICE (including SatNav)
    Last Post: 17th August 2011, 21:17
  5. door mirror wont work
    By phillip in forum Bodywork & Interior
    Last Post: 19th April 2009, 19:32
