Results 1 to 10 of 17
Thread: Cdti boost gauge fitting help
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Default Cdti boost gauge fitting help
    Hi all I am going to be fitting a mechanical boost gauge
    Question is if I drill a small hole on the rubber boost pipe from intercooler to inlet manifold on my 150cdti and push in the barbed t peice very tight then seal it with rubber glue will this be ok to run with also where is the best place to feed the vacuum tube to the drivers side dash mount
    Any
    help greatly appreciated asap
    Also is there not a vacuum pipe I can splice it into on the turbo or does it have to be the big rubber boost pipe thhanks
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    there will be a small vacume pipe somewhere if you put it on the large pipe if it ever pops out the car will go in to limp mode
    Regular Member LADmachining's Avatar
    Hampshire
    The small pipes don't actually carry boost pressure, they are control hoses for the wastegate and carry a vacuum. If you tap into them, you won't actually measure the boost pressure.
    Ideally, the adaptor to connect the gauge hose to should be screwed into a metal part of the intake manifold. This may mean dismantling parts and meticulously cleaning out any swarf resulting from the drilling and tapping of the hole.
    Regular Member CristianTM's Avatar
    ROMANIA, Eastern Europe
    I will show on my car how is fitted, but only later ...
    CristianTM.
    kings lynn, norfolk
    Yes please show me thanks looking forward to seeing some pics
    On a Sabbatical daviek's Avatar
    ayrshire scotland
    Quote Originally Posted by LADmachining View Post
    Wrong there buddy Hence the reason why most boost gauges show you a vacuum reading too .... the minus numbers. When a turbo engine is not boosting its running vacuum.
    Regular Member Marcosuk's Avatar
    Fife
    Quote Originally Posted by daviek View Post
    So thats why a gauge never sits at 0 then... Learn something new everyday
    Hampshire
    Not in a diesel engine. There is no throttle valve in a diesel inlet tract as there is on a petrol engine, so a vacuum cannot be created as the whole inlet system up to the intake valves is essentially open to atmosphere.
    The only caveat to this is on modern diesel engines which feature a motor controlled throttle flap which closes when the ignition is switched off. This is to strangle the engine and reduce vibration as it comes to a stop. A vacuum would be briefly created in the intake manifold in this instance.
    My original statement is still correct in relation to the OP's question - you cannot measure manifold boost pressure by tapping the gauge into the small vacuum control pipes connecting to the turbo wastegate or boost control solenoid. You will only ever measure varying levels of vacuum.
    Regular Member storm's Avatar
    Northumberland
    Quote Originally Posted by CristianTM View Post
    CristianTM.
    Do you have a piccy for us?
    Full Member Jay Kay 313's Avatar
    Burgess Hill
    When I fitted my gauge I dismantaled the front end of the car and removed the plastic intercooler pipe, drilled a 8th BSP tread to fit a brass take off that I got from Demon Tweaks, blow out all the swalf before refitting Have a look here think you'll need page two! HTH
    Astra Estate SRi XP 1.7 CDTi 100
  1. Can anyone help with boost gauge fitting?
    By simmo3187 in forum Diesel Engine related
    Last Post: 10th June 2012, 19:15
  2. Boost gauge cdti 150 fitting.
    By Avin in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2012, 16:20
  3. fitting boost gauge on a 2.0T
    By jay666 in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2010, 19:30
  4. Boost gauge fitting this weekend.
    By shippers in forum Vectra C / Signum Car Chat
    Last Post: 8th December 2009, 15:23
  5. PLEASE HELP fitting boost gauge
    By craigbarlow18 in forum Diesel Engine related
    Last Post: 31st October 2008, 19:09
vectra c boost gauge
corsa d diesel boost gauge
wherea to connect boost gauge corsa 1.7cdti
astra h cdti boost gauge wiring
how to fit boost gauge to a vectra c.
how to fit vectra cdti boost gauge
vectra c cdti boost gaugevectra c boost guage fittingvauxhall zafira turbo boost gaugemk5 astra sri cdti boost gaugeastra h diesel boost gaugevectra c boost gauge install kitboost cauge for opel corsa d 2010how to fit a boost gauge on corsa cfitting a boost gauge on a 1.9 zafira cdtiastra mk5 150 cdti boost gaugehow to fit the tubing to a turbo gauge on a corsa vxrdiesel boost gauge corsa cdtivauxhall vectra sri turbo boost gaugehow to link up a boost gauge to a astra dieselvectra c 1.9 fitting a boost control valvecan you fit a boost gauge to a dieselvectra c boost gauge fittingfitting boost gauge vectra cdtivacuum pipe fittings vectra c
