Results 1 to 10 of 15
Thread: VXR gearknob How2
    Regular Member george1987's Avatar
    Nov 2009
    Plymouth/Southampton
    Default VXR gearknob How2
    I've been having a look in the How2 section, but can't seem to find a How2 on fitting an astra VXR gearknob to a vectra c. Apart from bigron, does anyone know if their is a How2 on this? Cheers, George
    Nov 2009
    anyone?
    Sunny Dartmoor
    I know a few have fitted it George,its very straight forward,if you need a hand give me shout..........
    You basically need to keep the gaitor from your Vectra and cut the bit off the top to fit it to the Astra knob. You should see the chrome ring at the bottom of the knob itself and the a white bit underneath that which the gaitor sits between. Put the vec gaitor in there when cut, and push it all back together.
    It should be fairly obvious when you take it apart, but be prepared to do some cutting...
    Full Member spennny's Avatar
    Blantyre
    George, Very easy, do you have the whole stick, and the rod, small ball joint at the bottom ?
    You dont need to fit the whole plastic unit, i have done a few
    Nov 2009
    Quote Originally Posted by glenboy View Post
    Would really appreciate it Glen. Should be arriving Saturday or Monday, but probably won't be fitting it until end of this week
    Nov 2009
    Quote Originally Posted by spennny View Post
    Not too sure, will be arriving soon, so I will let you know
    Blantyre
    ok, stick a pic up once you get it so i see what your fitting
    Nov 2009
    what an idiot, I forgot about the pictures I was sent in a PM lol. Here it is.
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    Where did you get the gearknob from? Been looking around but no luck
  1. New Gearknob
    By Carl83 in forum Styling
    Last Post: 24th March 2012, 17:53
  2. Gearknob
    By scottg1123 in forum Bodywork & Interior
    Last Post: 26th March 2011, 20:13
  3. GearKnob Mod
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2009, 10:12
  4. VXR GearKnob
    By spennny in forum Styling
    Last Post: 23rd May 2009, 22:07
