Thread: can anybody help advice?
    Full Member paul.sessions's Avatar
    leighton buzzard
    Default can anybody help advice?
    can someone please tell me where the abs plug is i keep getting the same fault codes up u2103 u2108 u2139,traction control, abs, etc.. and i read somewhere that it could be a faulty plug (up to and including 2003 models) dodgy connections fingers crossed..
    the battery light, abs light and traction control light all come on.
    thanks
    or any other ideas if you have any
    Full Member Big Sig's Avatar
    HAVE A LOOK HERE
    Maybe you could do a how 2
    leighton buzzard
    lol cheers fella,
    this is what i found previously
    omega249826th July 2007, 10:22
    These were apparently a problem up until MY 2003.5, when a new plug was fitted in production, on all engines. See Field Remedy 1537 (TIS2000) which say `Failure of Instruments, swinging of Instruments, vehicle will not start, ABS lamp on, problems with storing trouble codes of ABS wheel speed sensor ... There is (was?) apparently a repair kit available, part number 93177022, and a `checking cable' part 93177928. Crimping parts were 90543865 and 09119561.
    has anybody done this repair.?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Not outside the dealer mate. I believe its just a case of cutting the old plug off and fitting a new one. If I remember rightly the individual pins in the plug aren't long enough so make poor contacts. All I did was give it a spray with WD40 and its been fine now for a couple of years.
    leighton buzzard
    cheers mate will give that a go then
  1. ebay advice , think someone is trying it on , need advice ...
    By poves in forum General Motoring Chat
    Last Post: 22nd August 2012, 00:29
  2. Need help and advice please
    By Angel1368 in forum Engine & Drivetrain
    Last Post: 9th June 2012, 11:19
  3. Need advice what would you do....
    By pipamish in forum General Motoring Chat
    Last Post: 2nd December 2011, 02:13
  4. Newbe after advice, lots of advice!
    By rb199 in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2011, 19:08
  5. Advice please?
    By RN37 VXL in forum Engine & Drivetrain
    Last Post: 16th October 2009, 17:59
