Results 1 to 10 of 13
Thread: no power cdti 150
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    Default no power cdti 150
    well was just starting to like the vectra again after its fare share of problems over the last year.but a couple of weeks ago started to loss power more so when cold and pulling away from junctions below 2000 revs already had new egr valve in march when problem was the same fixed it for awhile now today gutless again had egr off looks ok stripped not sticking but still flat new turbo fitted in jan had manifold last year had enough of it now think its time for a change unless any one has any other ideas ...
    CHESHIRE
    hello paul ,ive just read your post and from what you've stated it would seem you have covered most associated problems,that would cause loss of power .
    the only thing i can think of that mite help bring some power back ,is try a new air filter and fuel filter this worked for me when my car was suffering from lack of power .
    Full Member axelf's Avatar
    chester le street
    did you clean the boost sensor? and disconect the battery for about 1hr.....i done it on mine and it worked for me....could tel the differace straight away....hope it helps.......what filter you got in...have you tried a k&n..........if not you can come to me and try mine for a drive to see if it makes any differance....
    Feb 2007
    North west
    could be swirl valves stuck open - any smoke ? symptom is just like EGR valve however ...
    CHESHIRE
    Quote Originally Posted by axelf View Post
    hello axelf, quick question why disconect your battery cheers dave.
    chester le street
    some one said it clears the ecu memory or somthin....that why i did it....
    CHESHIRE
    yeah what i thought to be honest, those it actually work to reset the ecu?..
    durham
    thanks for the replies guys took egr apart last night nothing to see wasn't stuck, put it back together went to work this morning ran spot on .rang vauxhall tech this morn wait for it they said ecu playing up dont think so as it runs ok above 2000rpm but with no warranty on car not prepared to spend that sort of money on a guess . going to try fitting blanking gaskets and see what happens .when it runs ok its great to drive but its been a lot of problems.
    durham
    just remembered already done boost sensor and reset ecu ..
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    manifold has probably fallen apart being a 1.9
  1. No power from 1.9 cdti 150
    By garetmcc79 in forum Engine & Drivetrain
    Last Post: 1st April 2012, 08:04
  2. 1.9 cdti 150 no power
    By baz_cdti_sri_150 in forum Engine & Drivetrain
    Last Post: 3rd October 2010, 15:00
  3. little power 150 cdti
    By smokydiesel in forum Engine & Drivetrain
    Last Post: 26th May 2010, 19:13
  4. 150 cdti with no power
    By pauly in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2009, 00:23
  5. 150 Cdti down on power??
    By shrekster in forum Engine & Drivetrain
    Last Post: 7th December 2008, 00:19
