Results 1 to 10 of 14
Thread: Rear jetwash-no fluid
    Regular Member Fash's Avatar
    Doncaster
    Default Rear jetwash-no fluid
    Hi, having a problem with my rear jetwash (04 sri cdti-hatch)..When pushing the stalk in you can hear the washer pump making a noise, however no liquid comes out the rear nozzle. Have taken the rear nozzle out and no fluid is coming down the pipe at all...Front jets work fine...
    Anyone else had this problem, or have any ideas ?
    Thanks,
    Steve
    Regular Member larrysSRI's Avatar
    Nov 2009
    south wales
    I have the same problem with this and am interested to know a solution too
    Full Member Big Sig's Avatar
    Have you removed and cleaned the pump and filter? there is a how 2 for this.
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Beaten to it by Big Sig. (you must spend your life watching the new threads :-))
    Quote Originally Posted by s_zigmond View Post
    Sometimes
    May 2008
    Derbyshire (south)
    Possibly the pipe has come off at the pump also, have someone work the switch & see if the fluid hit the floor. I have also found on mine, that if the rear washer doesn't send water. then my bottle is low too.
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    i had this a week or so ago on the father in laws vec c just use a needle to poke in the jet give it a wiggle then operate the pump repeat a few times then adjust the spray correctly
    Doncaster
    No mate, do you have a quick link to the specific "how to" ?
    Thanks, Steve
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    when mine was not working i pulled the washer out of the aerial carefully the took the pipe off and then remove the washer cap off the bottle under the bonnet. then i got one of them tyre inflators you plug in the cigar point and put the end of that into the pipe,turned it on and then when you see water coming out of the washer bottle the blockage has gone hope this makes sense
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Mine was blocked under the front nearside wheel arch and I cut the pipe under the front scuttle and blew it out and then used a joiner job jobbed
  1. Jetwash DPF
    By rockonoli1 in forum Engine & Drivetrain
    Last Post: 14th May 2011, 15:48
  2. Fluid on the rear brake calliper
    By tony_b in forum Suspension, Wheels & Brakes
    Last Post: 16th March 2011, 13:33
  3. Jetwash....
    By Signum_CDTI in forum Detailing and Car Care Discussion
    Last Post: 5th March 2008, 23:12
  4. karcher jetwash
    By vectra sri dan in forum General items for sale
    Last Post: 25th November 2006, 10:10
  5. Jetwash
    By AndrewTi in forum General items for sale
    Last Post: 16th April 2006, 11:34
