Results 1 to 10 of 13
Thread: dmf + clutch fixed and knocking still there
    north east
    Default dmf + clutch fixed and knocking still there
    cant belive my look just got dmf , clutch kit and new starter motor costing over £700 all fitted and still have knocking
    the problem is a lot better than before but theres a humming noise when i stop accelerating, but stops when i put the cluth in and theres still a knocking over 50 on the front passenger side, its a lot better but not gone
    the garage reckons its the drive shaft now but i dont know
    just seems as if im chucking money at this car
    anyone had a similar propblem or know what it might be
    thanx
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    i am having my inner osf cv joint replaced on monday when they do my dmf and clutch, mine is shot to pieces.. some people find that their dmf has nailed their starter motor, but i can't guarantee that this is your fault..
    btw i way i bought my replacement genuine vx cv joint from vauxhall green parts for £45 delivered, better than the £179 + vat that my vx stealer wanted.. and also better than a complete new driveshaft from the stealer at £470 + vat. Don't know about the humming noise though...
    north east
    thanx for the reply,
    i heard that the starter motor could be knakered by the dual mass so i took the plunge with the repair
    but i heard that they have to take the nearside driveshaft off to get to the dual mass, if thats true then maybe the garage have put it back on wrong or lost somthing off it
    Jun 2009
    South Coast
    check with vx but for some models you have to replace the whole driveshaft but some you can just replace the parts of it like the cv joints etc..
    north east
    well about 6 weeks ago i had my passenger side cv joint changed at a different garage but dont know wether it needed a full shaft
    by the way my car is a 2.0 dti ls 04 plate
    Jun 2009
    South Coast
    is that the one they are now saying is knackered? how much did you pay for the cv joint 6 weeks ago, that will give you an indication of what was replaced, you can buy cheap patent CV joints for about £25 but i don't know how good they are.
    north east
    think it cost about £150 thats with fitting and vat included dont know it that helps ? where can you get the patent cv joints from?
    Jun 2009
    South Coast
    sounds like they just replaced the joint then.. you can guy the patent CV joints from a well know internet auction site..
    what side is supposed to have gone, is the same side you had done last month?
    north east
    im not too sure il have to get the reciepts out but do you think it maybe the garages fault were they taken the old driveshaft out to get to the gaerbox?
    Jun 2009
    South Coast
    who knows, but they laster longer than six weeks... there are two cv joints per driveshaft though (inner and outer).. you need to know what one is at fault and know which one was recently replaced..
  1. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  2. Front end Knocking Fixed for £1
    By ScotsDragon in forum Suspension, Wheels & Brakes
    Last Post: 27th February 2011, 18:15
  3. 2.2 DTI - Knocking/vibration after crank pulley change - FIXED
    By shaun260589 in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2011, 18:07
  4. Rattle/knocking noise with clutch depresed
    By bobmoss in forum Engine & Drivetrain
    Last Post: 9th May 2010, 15:56
  5. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
vectra clutch knocking
