Results 1 to 10 of 11
Thread: Cdti boost guage
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Default Cdti boost guage
    Is there a how to for this where do I plug on the t piece for the Reading thnks guys
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    on the small vacume pipe for the turbo mate
    kings lynn, norfolk
    Where is that pipe for the turbo also will that give the correct Reading I though it had to be on the manifold boost pipe. It will be great if I can just put a t piece in to the small turbo pipe also how do you run the vacuum pipe through the bulkhead to the drivers side dash at the top next to the windscreen
    Any help much appreciated I take it any boost gauge that reads 30psi will do also where do you attach the illumination wires too cheers all
    Regular Member storm's Avatar
    Northumberland
    Quote Originally Posted by winnie2457 View Post
    does anybody know where that pipe is as im trying to do the same thing right now lol
    kings lynn, norfolk
    Is this an easy job to do and will a mechanical boost gauge be ok as I'm on a budget
    hope someone can help I have had a look in my engine bay and can only see small vacuum pipes are these the ones the t piece goes into?
    kings lynn, norfolk
    Bump
    kings lynn, norfolk
    Hi guys was wondering if any one out there can help I am looking at a smoke mechanical boost gauge on the bay with all fittings pipe and t peice now I have heard you can't use the vacuum pipe off the turbo as it does not work bit why? Also if I drill a small hole in my boost pipe intercooler to inlet manifold the rubber one and push the barbed t peice in so it's really tight fit then seal it with rubber glue so it's air tight will that be ok to supply my boost gauge
    And also how loud is the mechanical boost gauge as I have heard they are noisey in the cabin can some one please help me asap thanks guys
    kings lynn, norfolk
    well i have decided how i am going to fit my boost guage and i am going to drill a small hole into the rubber boost pipe just before it goes onto the manifold i am going to drill small hole then push into it the barbed t piece so its a very tight fit and thr barbs means it wont come out then i am going to use silicone to seal it around the t peice once it sets then i will be ready to fit the pipe onto it and seal of one end of the t piece also if it does go wrong and i need to take it out i can just bandage up the pipe with duck tape so its air tight till i can afford to replace it
    what do you guys think i iwll post up pics once fitted by the way
    Regular Member CristianTM's Avatar
    ROMANIA, Eastern Europe
    Must use "no buzz" T piece for not making noise and quality boost gauge. See thhis link --> http://www.autodials.co.uk/
    CristianTM.
    kings lynn, norfolk
    I will try without the no buzz 1st if it's bad then I might try instead a regulator. Valve from my aquarium to splice in the boost gauge hose it has a screw valve on top so I coils screw it closed untill I get no buzz and a correct Reading I will take some pics while fitting it to do a how2 for the cdti
  1. Boost Guage
    By viper8 in forum Vectra C / Signum Car Chat
    Last Post: 27th July 2011, 21:16
  2. boost guage pics(2.0 dti)
    By Pulja in forum Diesel Engine related
    Last Post: 2nd July 2011, 23:54
  3. boost guage...
    Last Post: 27th June 2011, 10:47
  4. z20net boost guage fitted
    By Marcosuk in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2010, 13:49
  5. boost guage
    By wiggy in forum Vectra C / Signum Car Chat
    Last Post: 15th March 2009, 22:13
