Results 1 to 3 of 3
Thread: Coolant leak
    Newcastle upon Tyne
    confused Coolant leak
    Got in the car this morning and the indicator was on saying that there was not enough coolant in the car. As I did'nt have any on me I topped it up with water just to get me to work. On pulling into the car park at work the light came back on. Do you think this is a split pipe or something more serisous?
    Regular Member djr69uk's Avatar
    Midlands
    if it's using coolant that quickly then chances are you are losing coolant from a hose or punctured rad or something - either way you should see signs of coolant on the road under the car or dripping from the undertray.
    if everything is nice and dry under the car and under the bonnet then it must be losing coolant into the engine - in which case you might be looking at head gasket failure. check for white smoke in that case and get a garage to dip the header tank.
    either way check in and under the engine bay for signs of a leak. hopefully you'll spot something!
    what engine is it? mileage etc..?
    Newcastle upon Tyne
    Unhappy Coolant
    Thanks for the info.
    Found out what the problem was when I noticed that the leak was coming out beside the nearside front wheel, the water pump is knackered.
    £240 to have a new one fitted at the local dearlership !!!!
  1. coolant leak
    By DavyB in forum Insignia car chat
    Last Post: 17th May 2012, 09:04
  2. Coolant Leak
    By Sike in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2012, 13:52
  3. Coolant leak
    By Vin in forum Engine & Drivetrain
    Last Post: 2nd February 2011, 22:49
  4. Coolant Leak
    By trickydickySRI in forum Vectra C / Signum Troubleshooting
    Last Post: 20th April 2009, 09:25
  5. Coolant Leak???
    By ChrisFox in forum Vectra C / Signum Car Chat
    Last Post: 19th January 2009, 05:46
