Results 1 to 2 of 2
Thread: no fuel
    sutton coldfield
    Default no fuel
    hi there , hope somebody may be able to help me on here i have a vauxhall signum 2.0 diesel turbo (not common rail ) with no fuel (non start ) is there a low pressure pump in the tank or any were else for that matter its a 2003 model , there is a 20 amp fuse in the fuse box in the boot , which according to the handbook is for the fuel pump ,but not sure if that is somethink to do with the fuel pump on the engine .as i say its the old mechanical type not the common rail type .
    nigel
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    no tank or scavenge pump its the injector seals
  1. 2.2 direct fuel pump and fuel pressure regulator
    By w111y in forum Engine & Drivetrain
    Last Post: 11th July 2012, 22:12
  2. Fuel housing sensor/fuel temp senser a
    By sri adi in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2010, 10:15
  3. high pressur fuel pump and fuel regulator ?
    By simplesi in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2010, 12:23
  4. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
