Results 1 to 3 of 3
Thread: CDTI 150 engine light.
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    Default CDTI 150 engine light.
    Hi guys. I drive to and from work each day, 9 miles each way. Since Monday afternoon 3/4 of the way through each journey the engine light has appeared and there's been a slight drop in power.
    I have a code reader, but no codes show (present or pending). The reader allows me to reset the code.
    I tried the ignition/accelerator/brake pedal How2 without success and noticed this afternoon with all of the fiddling with the ignition that the fault went out itself.
    Around 6 weeks ago, i cleaned the EGR valve and boost sensor.
    Any ideas what it might be?
    Jan 2010
    Trim : Sri nav
    Engine : Z19dth
    It turns out it was the spanner light. Cleaned the fuel filter out, but it appeared again the next day. Same thing, limp mode, no power.
    Went out today and the engine light came on this time. Code read as P2279 Intake Air System Leak. Ended up having to pull over as the engine wouldn't idle and kept stalling.
    Got towed home. Upon checking later i found an oily pipe leading to the turbo (pipe from air intake to turbo). I tried to remove it to see if it was split, but the engine was still a little hot. I'll have another go tomorow.
    Anyone fitted one of these before?
    Jan 2010
    Trim : Sri nav
    Engine : Z19dth
    Got the pipe off to clean and inspect it yesterday. It wasn't split, so i refitted it. The error code P2279 still appears once you try to rev above 3000.
    Looks like i'll be off to the garage tomorrow to try and get it booked it.
  1. CDTI Check engine light
    By Derek Mc in forum Engine & Drivetrain
    Last Post: 20th May 2010, 18:17
  2. Engine management light on cdti 150
    By peadar in forum Diesel Engine related
    Last Post: 9th April 2010, 23:03
  3. cdti lacks power when cold, & engine light on
    By mr_dog in forum Engine & Drivetrain
    Last Post: 8th February 2010, 22:45
  4. Signum 1.9 (150) CDTI Emissions (Engine Light)
    By Claire@austin141273. in forum Engine & Drivetrain
    Last Post: 9th January 2009, 21:29
  5. Help on 1.9 cdti sri (engine light)
    By tonyx420 in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2006, 22:03
