Thread: near side front wheel knock
    Regular Member myelite150's Avatar
    Nov 2009
    south wales,Cwmbran
    Default near side front wheel knock
    hi muckers
    i got a problem that every time i turn right theres a little single knock coming from the n/s front wheel has anybody got any ideas before i take a peak so i can sort it out quicker
    cheers
    HIFI
    Regular Member gsi.vxr's Avatar
    Hertfordshire
    Probably Stabiliser Link.
    If not, broken coil spring or CV joint, maybe? Stab link is cheapest to do first.
    East Midlands
    Could be the strut top bearing,get someone to sit in the car and operate the steering from lock to lock while you place your hand on top of the strut inside the engine bay,sometimes a knock can be felt.
    Regular Member JudgeApocalypse's Avatar
    Apr 2009
    Anglesey
    Hi, had this on mine DO please check it before driving the car! There is a brake pipe that can catch on the spring cup on the suspension leg, wearing at it and making a knocking sound. Mine was nearly worn through and needed replacing, has a different bend shape to the offside pipe. I have lowered springs on mine prehaps that didn't help or it may have dislodged when I had a spring break on that side? Either way worth checking.
    Nov 2009
    south wales,Cwmbran
    ta guys coils springs brand new but never say never
  1. Play in passenger side front wheel hub!
    By Jow20 in forum Suspension, Wheels & Brakes
    Last Post: 14th February 2013, 14:25
  2. Clunk from driver side front wheel?
    By rosssri in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2011, 07:37
  3. play in front passengers side wheel bearing
    By wilsons 1.8sxi in forum Suspension, Wheels & Brakes
    Last Post: 22nd June 2009, 17:14
  4. Front bang/knock noise on turning wheel
    By NPS in forum Suspension, Wheels & Brakes
    Last Post: 14th January 2009, 19:58
  5. knock coming from front off side???
    By gizmo10119 in forum Suspension, Wheels & Brakes
    Last Post: 2nd August 2005, 08:01
