Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Aircon question
  1. #11
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    Have you tried it with the recirculation on? Apparently this is the most efficient setting for aircon & the fact that it will cool down already cool air, should mean that the temp goes lower than 16c, or i could be wrong.
  2. #12
    Quote Originally Posted by kentish_bloke View Post
    Perfectly right mate - stands to reason. It's the same reason you shouldn't put the blowers on full when trying the heat up your car from cold, as drawing in the outside air more will only keep the engine cooler for longer. Obviously this isn't the case if you select recirculation.
    The climate contol in the Vec/Signum is quite clever in this respect - if you select a high heat from starting the engine cold it only turns the fan up to blow it as the engine temperature rises...
  1. Another aircon question
    By 111 in forum Vectra C / Signum Troubleshooting
    Last Post: 19th December 2011, 01:36
  2. another aircon question
    By kirky2k4 in forum Vectra C / Signum Car Chat
    Last Post: 11th April 2011, 01:38
  3. Question about aircon
    By Ralphwells1967 in forum Vectra C / Signum Car Chat
    Last Post: 28th June 2010, 16:23
  4. aircon question
    By monty2000 in forum Vectra C / Signum Troubleshooting
    Last Post: 25th June 2010, 13:49
  5. Sorry Another Aircon Question
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2008, 11:14
