Thread: Air con on the blink?
    near Glasgow
    confused Air con on the blink?
    Looking for a few suggestions guys (and gals! ).
    A few days ago I got into the vectra to find a huge puddle in the front passenger footwell (also, the air con is not now working). First thought was - There's a leak in the coolong system, so went out a got a sealant. Added that to the system, just realising at the same time that the level wasn't actually down (and there was no smell coming from the puddle). Did a bit of 'googling' and then checked the pollen filter, cleared a pile of leaves and checked all the fuses. Since joining the forum (today) and looking at a couple of other posts, am I right in thinking that the air-con system is seperate from the coolong system. If so, how would I go about checking this, can it be fixed with sealant, or is this really a job for vauxhall?
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Have you checked ALL the fuses - there's a fusebox at the end of the dash & one in the engine compartment
    Does the heater fan still work?
    Newcastle upon Tyne
    are you vents blowing? is it just the AC not working?
    near Glasgow
    confused Nothing blowing
    Quote Originally Posted by j88nya View Post
    No, the vents aren't blowing, although I think I can hear a light click when I try to turn them on. Thought this was perhaps some kind of safety cut-out, when the system was empty, to prevent the unit from going. Problem is, if this is a seperate system from the cooling system in the engine, I wouldn't know where to fill/top it up, to see if that was the problem.
    near Glasgow
    Default No heater fan.
    Quote Originally Posted by Ian S100 View Post
    Yes, I've checked them all, for any fuse to do with air-con, cooling, ventilation, etc.
    Last edited by Chop Suey; 14th April 2010 at 16:33. Reason: forgot to add something
    Full Member spennny's Avatar
    Blantyre
    The aircon system has a shut off switch if the oil level gets to low, it is a diff system and can be topped up albeit proffesionally i would recommend, or kwik fit do it for £40 i think
    But it does have a shut off valve
    near Glasgow
    Default Post in the wrong place?
    Quote Originally Posted by Chop Suey View Post
    Just realised where this post is. I should probably have posted this in the Technical section. If anyone from Admin wants to correct this error, I'd be grateful.
    Newcastle upon Tyne
    Sorry I meant do the heaters blow? Is it just the ac not working?
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Moved from "Problems with the forum an registering" to HVAC
  1. Alpine CDE-113BT On the blink!?
    By shiver2k11 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd April 2012, 20:16
  2. Dash on blink!!!!
    By s2yob in forum Bodywork & Interior
    Last Post: 18th December 2011, 23:24
  3. Air Con on the blink.
    By WilliamLX in forum Vectra C / Signum Car Chat
    Last Post: 31st August 2010, 21:22
  4. Steering Wheel controls on blink
    By Al Adams in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2008, 12:03
