Results 1 to 10 of 17
Thread: Car "stuttering"
    Nov 2009
    Wirral
    Default Car "stuttering"
    Hi,
    My vectra 2006 elite 2.2 direct Injection has a problem,
    It happens in most gears and the best way to describe it is it feels as though the car is running out of fuel or the fuel isnt getting through.
    It happens usually when i put my foot about a quarter on the accelerator the car pulls then doesnt then does again, it keeps doing this. if i put my foot right down problem goes away.
    any ideas?
    Regular Member kamar's Avatar
    bradford
    check fuel filter or uve got a fault with ur fuel pump coz may b the fuel isnt getting through but again it can be stuff like coil packs, spark plugs, etc...
    Nov 2009
    Wirral
    oh ok, so it isnt a known issue then? better get it in to a garage.
    bradford
    ur best place mate cheers
    Nov 2009
    Wirral
    Hi,
    Ok car has been in to garage plugged in to the machine and had no faults. Changed the spark plus for some new, expensive ones. Changed the fuel filter changed the fuel from Tesco to BP
    Car still exactly the same
    Changed Coilpack
    Car exactly the same.
    Car drives in 1st ok, change to second from about 2500 rmp through till about 4500 rpm it feels like an old car with the choke out intermitting loss of about 15% power on pull. This happens in all the gears through and including 6th
    Mechanic has no idea, do any of you folk?
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    sounds like the high pressure fuel pump or the regulator ring vx and see if your car is covered by the recall
    Nov 2009
    Wirral
    Quote Originally Posted by cerbrious View Post
    Hi mate, any ideas where i can check this recall proceedure?
    Jan 2010
    glasgow
    some pumps and fprs dont show up a fault phone ur local vaux dealer and ask them if its coverd for the recall the fuel regulator and pumps are comon faults on the 2,2 and so is the timing chain and tensioner
    Nov 2009
    Wirral
    yep sounds like a rough bag of spanners for the first 3 mins after cold start up
    Jan 2010
    glasgow
    i think my tensioner is on its way out very slight noise on first start up for first few seconds if your cars rattling on start up for a good 3 mins id say ur tensioner is gone and pos giving u chain probs if i wer u id get it lookt at asap if it snaps or slackens rite off it will do the chain ur head valves etc
  1. "Winter" Wheels ? Are 19" Snowies best for the "Summer" ?
    By Woody in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2012, 18:43
  2. worried!!!! have you ever used "corsa centre" or "supernovas"
    By vectra_c_wannabe in forum The 'Off Topic' room
    Last Post: 20th May 2009, 15:21
  3. "Goodbye" blue sky "Hello" grey !
    By FIL 4822 in forum General Chat
    Last Post: 8th November 2008, 15:43
  4. "Goodbye" grey sky, "hello" blue !
    Last Post: 24th October 2008, 12:34
  5. end of year bash 2008 "" will there be one ""
    By chrisgettings in forum General Chat
    Last Post: 3rd September 2008, 10:26
