Results 1 to 10 of 11
Thread: Advice for new install please!!
    Jul 2006
    Cool Advice for new install please!!
    Right,
    I have just acquired a Pioneer head unit, and fascia adaptor. Before I spend another 20 quid on the wiring adaptor, does anyone know - or can anyone find out....
    I read somewhere that the only problem with Vx wiring loom is that the switched and constant live wires are the wrong way round, so you would lose all your settings every time you turn the ignition off.
    Is this right? If so, it seems stupid to fork out any money at all when I could just cut and re-splice the existing wires...
    look forward to any opinions
    Regular Member Spikeyİ's Avatar
    Dec 2005
    In the sponge-monkey tent
    should be a red and a yellow wire, just swap them around, usually they will have plugs on to make this easy.
    Regular Member Harry's Avatar
    Uxbridge, London
    what he said.
    Jul 2006
    nice one chaps.
    will try to fit it today while at work - got my wire coat hanger ready to rip out the old one!!
    let you know how it goes
    Jul 2006
    Just to set the record straight -
    the Vx wiring loom is NOT compatible with ISO standard, so I will sadly need the extortionately priced wiring adaptor.
    more suprisingly, the antenna cable is non-standard too. suspicious that none of the main ICE suppliers have an adaptor.....
    if anyone knows anywhere cheap to get hold of the wiring adaptor from, it would be appreciated. also, anyone else who has done their install already, where on earth did you get the antenna cable adaptor from?
    here's hoping.....!
    Regular Member Matt21385's Avatar
    Ayrshire Scotland
    Trim : VXR
    Engine : 2.8 V6
    Have you bought a facia kit yet? You will get one from vx plus the wiring loom that you should need for about £25
    Jan 2006
    Skynet HQ EMEC#5
    When I bought the vx facia adapter, the harness adapter was with it. Also I fitted a Sony head unit, the small adapter plug to connect aerial to head unit was with it.
    Any car accessory store should have the aerial adapters.
    Dec 2005
    Halfrauds even do a compatible wiring loom in their fascia kit. They also supply arial adaptors for about £1.50.
    this is the one you want
    i know it says for the astra b4 anyones comments
    but its also listed for the vec with CANBUS
    you will see it has got the canbus style aerial adapter (not the normal £1.50 ADAPTER)
    http://www.raysmith.co.uk/product_in...oducts_id=3066
    or http://caraudio.ie/view_product.php?partno=PC2854
    Jul 2006
    vectra 2.0 t
    thanks!!!!!
  1. My ICE Install. Set Up/Settings Advice?
    By paz_badboy4life in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2012, 13:46
  2. Need Help with new ICE install
    By Drazek in forum Electrical & ICE (including SatNav)
    Last Post: 12th January 2010, 13:07
  3. ADVICE NEEDED. Rear Interior Light Install.
    By paz_badboy4life in forum Bodywork & Interior
    Last Post: 28th December 2009, 18:55
  4. new install
    By middler31 in forum Electrical & ICE (including SatNav)
    Last Post: 28th January 2009, 01:29
  5. DVD install advice req'd
    By sharpy in forum Electrical & ICE (including SatNav)
    Last Post: 25th July 2006, 12:01
