Thread: Vectra Radiator Leak
    leeds
    Default Vectra Radiator Leak
    i just bought vectra c 03 reg , i realize there is some water drop under radiator on driver side , i am sure its water as it doesn't smell , some on told me its may be from air con and some say its miner leak from radiator , can some one help me if having or had same problem the leak is very minor so i cant say if my coolant water drop or not , i bought K-seal coolant leak repair but i am not sure if to use it or not.
    i will be very glad if some one help me
    thank u
    Jul 2009
    The Rift, Cardiff
    I had a leak and got a new rad, I personaly wouldn't use a rad seal type product.
    A good way of finding a leak is to look for steam when the engine is hot, preferably on a cold evening with a torch. Maybe you can then be sure if its the coolant rad or the aircon rad.
    Regular Member Jow20's Avatar
    Sep 2010
    Leeds
    Quote Originally Posted by salmanking View Post
    thank u
    This is exactly my symptom apart from ive noticed the coolant is very slowly going down, also my cabin is steaming up in the last few days. Has anyone found out if it is aircon or rad...? And what to do?
    Regular Member matt.d's Avatar
    May 2011
    gravesend
    Vehicle : vectra c
    Trim : breeze
    Engine : 1.8 16v petrol
    could be your heater matrix
  1. Radiator leak
    By dansoap in forum Engine & Drivetrain
    Last Post: 22nd April 2011, 21:22
  2. Radiator Leak
    By si_hoss in forum Engine & Drivetrain
    Last Post: 10th June 2010, 13:13
  3. vectra c 2003 radiator leak ?
    By sparks in forum Engine & Drivetrain
    Last Post: 23rd January 2010, 19:47
  4. 1.8 sxi radiator leak
    By bat30 in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2009, 12:51
  5. radiator leak
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2008, 07:17
vectra c radiator leak passenger side
leak at bottom of radiator on vectra c
vectra 1.8 radiator leak
vauxhall vectra radiator leak
vauxhall vectra c radiator
vectra c radiator coolant leak bottom left
