Thread: tailgate light
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    Default tailgate light
    how easy is it toi change the tailgate light to a smoked one? also where is the best place to get one from and roughly how much are they?
    Regular Member sristeven1's Avatar
    wirral
    takes about 5 min a side mate you can get them off ebay seen a few on there
    Feb 2007
    i was on about the one in the boot mate sorry if it wasnt very clear!!
    Norwich
    Trim : SXi
    Engine : 2.2
    You mean the 3rd brake light - dunno never done it
    Feb 2007
    yes the boot/tailgate light????? thanks for your input
    wirral
    from what i have heard they can be a nightmear to get the old light out and fitting the new one
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    i'm sure theres a how2 on here, but cant find it. from memory, you remove the tailgate trim & locate where the light is, there should be a few indentations on the inside of where the light is fixed, you need to drill through these to allow you to then push it out from inside. you shouldnt prise it out from the outside as you will most definitely damage the paintwork.
    ive seen a light for sale on fleabay, was £20.99 when i last looked, but i think new ones from the stealers are somewhere around the £30 mark, but dont quote me!
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I may be wrong here but i'm sure you use an old credit card cut up and shove bits of the card all the way round the light but I have never personally done it
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    hmmm, not heard that one before, but it could work. I've seen something similar done with metal wedges used to get a locked manhole cover up, worked a treat, so no reason why the above method wouldn't work, worth a try.
    Regular Member Ben_'s Avatar
    Audiville, WM
    when i changed mine, i had to pretty much smash the old one out. Just prize it gently with a knife (cover paintwork first tho) take your time and you'll lever it out eventually.........good luck
  1. tailgate light cluster not working on o/s
    By leesheridan in forum Electrical & ICE (including SatNav)
    Last Post: 3rd July 2012, 16:54
  2. Replacing rear light bulb in estate tailgate. How?
    By Marky in forum Electrical & ICE (including SatNav)
    Last Post: 10th November 2009, 14:07
  3. Can the tailgate light be turned off
    By Pjuk in forum Vectra C / Signum Car Chat
    Last Post: 31st July 2008, 05:23
