Thread: Possible air con issue
    Oct 2007
    Gloucester
    Default Possible air con issue
    With the summer trying it's damnedest to warm us, I turned the air con on the other day only to be met with nothing. Usually, it makes a slight squeaking noise but still manages to blow cold air at me.
    This week, nothing.
    What I need to know is whether an air-con unit that needs regassing will do anything at all in terms of cooling?
    If the air con compressor has packed up (it was replaced 2 years ago) the car may well find itself being torched!!!
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    It may well do but mine isn't cooling the air by much at the mo so maybe it's just the cooler temperatures
    Oct 2007
    Gloucester
    It's not cooling it a jot. It usually feels colder even when it's cold outside.
    I did turn it on when the car was idling too - the revs increased slightly which did make me think that the compressor is turning on. Not certain why the squeak has disappeared though.
    5 Post(s)
    Did you run the AC through winter at all?
    Needs to be run up at least once a fortnight to help prevent rubber seals from drying out.
    Full Member Big Sig's Avatar
    Not using it at all during the winter does exactly that.
    Mar 2007
    Southport
    I gave mine a run whenever I thought about it which was probably every few weeks - I'll probably have to get mine recharged too by the sound of it
    Oct 2007
    Gloucester
    I did run it occasionally - though not regularly.
    If the seals have gone is it an expensive repair?
    5 Post(s)
    You *might* be lucky in that they recover once the system has been refilled with the correct quantity of refrigerant and oil.
  1. Air con issue
    By harts1.9design in forum Electrical & ICE (including SatNav)
    Last Post: 12th June 2012, 11:26
  2. hid issue
    By Morephun in forum Electrical & ICE (including SatNav)
    Last Post: 30th June 2011, 10:30
  3. Hid a serious issue ?
    By Elahi_786 in forum Electrical & ICE (including SatNav)
    Last Post: 29th November 2010, 02:28
  4. DAB issue
    By qsdjdan in forum Electrical & ICE (including SatNav)
    Last Post: 20th January 2010, 01:12
  5. key fob issue
    By doghead632 in forum Bodywork & Interior
    Last Post: 25th August 2009, 10:22
