Thread: Dodgy heater!
    Regular Member keith1983's Avatar
    Sheffield / Spalding
    Vehicle : Vectra 1.8 SRi
    Engine : Z18XE
    Default Dodgy heater!
    My heater has started playing up and the blower only works on setting number four. Has anyone else had this problem? If so what was the solution?
    Newcastle upon Tyne
    Have you had water in the passenger footwell?
    Engine : Z18XE
    not that I've noticed? If I have what would that indicate?
    Regular Member benwalters82's Avatar
    Nov 2009
    Redruth
    Trim : SXI
    Engine : 2.0DTI
    Year : 2002
    Full Member Big Sig's Avatar
    Quote Originally Posted by benwalters82 View Post
    How did you find that???
    Newcastle upon Tyne
    check that post out, very common problem so i would start by checking your drains asap. I had my heaters go off the other month it was caused by water damage from a blocked drain (the drain was cleared over 6 months before and it took that long for fault to develop! On mine its slightly different as i have duel climate control but i managed to fix it with a can of WD40! Basically the connections on the resistor were totally eroded. To fix i carefully cleaned up the points as best i could by scraping as much c**p as i could then sprayed it with WD40 (this is good cos does not conduct electric but prevents rust/erosion)put it back together and it worked a treat. i did the same with every connector i could get to from behind the glovebox to try and avoid any future problems! Also a tip my heaters have never worked as well since i put a bit 3in1 in on the top of the motor (behind pollen filter get to from engine bay) they did have a slight squeek but better then new now! Hope this helps and you dont have to spend you hard earned £££ because of poor VX design!
    Engine : Z18XE
    Thanks for the info guys. Certainly gonna give the resistor pack, drain clearing a go and see how I get on. I just hope the motor is ok. It does work well on setting 4 so fingers crossed!
    Nov 2009
    Redruth
    Trim : SXI
    Engine : 2.0DTI
    Year : 2002
    remember to try the 79p maplins fix before forkin out on a new resistor pack.
  1. Dodgy DAB....
    By JagRigger in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2011, 08:01
  2. hid kit dodgy?
    By duncan2008 in forum Electrical & ICE (including SatNav)
    Last Post: 12th May 2009, 17:32
  3. dodgy egr i think!
    By littlesxi in forum Diesel Engine related
    Last Post: 21st March 2008, 23:59
  4. Dodgy Ref
    By AJA in forum Comedy & Humour
    Last Post: 11th February 2007, 04:51
