Thread: Help please!! Limp mode...
    Sep 2009
    midlands
    Default Help please!! Limp mode...
    Hi all, I would really appreciate some input on this one!
    My 1.9 CDTI keeps getting the spanner light and going into limp mode, but no error codes are being stored. Wierd thing is its following a pattern...I drive 10 mins through town to the motorway, temp gets up to 80, then 5 mins cruising on the motorway, temp drops, and then spanner/limp kicks in. It`s done this 3 times now, about the same spot on the motorway each time. Turn off, wait 5 mins and its fine for another 30motorway miles til I get home.
    Vauxhall cant find any stored codes, they say it`s fine!
    Could it be temperature related? Stuck thermostat throw up a spanner? I`m being cautious on the motorway at the mo, but I`m getting really nervous every time I get on!
    Thanks in advance!
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Other than the limp mode are you getting any loss of power before hand, how does it start smooth or lumpy, any smoke ?. it could be thermostat related or egr, have you tried looking through the how 2 section at boost sensor + egr cleaning it wouldn't harm and would rule these out.
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    Sounds like the problem that i've just started to get.
    http://www.vectra-c.com/forum/showthread.php?t=108119
    Sep 2009
    midlands
    Hi folks, sorry for the delay in responding.
    No wizard, it starts/ idles fine, no smoke, and before and after limp it pulls like a train, though it does have the flat spot we`re all so familiar with up to 1900rpm. I cleaned the egr + boost sensor last september I think, maybe worth doing again though.I s it worth cleaning the throttle body d`you think?
    Do problems like the egr always throw up fault codes?
    So many questions lol...
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Its worth doing the throttle body, and the egr can throw up fault codes but NOT always, mine usually dont!.
    Sep 2009
    midlands
    cleaned the throttle body last night, not as bad as I thought it would be actually, bit gunky but still able to close + open.
    Forgot to mention, just had a new inlet manifold and actuator but I didnt change the egr at the same time. So today its clean egr, but is there any way to test its working while its off? Maybe take it off leaving it plugged in, cover the aperture on the manifold and see what it does when reved?
  1. Limp mode help
    By neill in forum Engine & Drivetrain
    Last Post: 20th March 2012, 19:53
  2. Limp mode or dead mode
    By JSYSH466Y in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 09:46
  3. Limp mode
    By dan1983 in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2008, 18:35
  4. Limp mode
    Last Post: 3rd July 2008, 10:34
  5. limp mode
    By vauxvec in forum Vectra C / Signum Car Chat
    Last Post: 15th June 2008, 22:03
