Results 1 to 3 of 3
Thread: wheel Vibration
    Regular Member eaglepva's Avatar
    Up North
    Default wheel Vibration
    When driving my car on the motorway i get a vibration coming throught the weel, Ive had the tires balanced etc. Recently had new disks and pads on the front and the fitter said that the drivers side tie rod or tie rod bar or something like that is a little worn which is probs the cause of the vibration. Can anybody confirm the correct part that i need to buy and if anybody knows is it easy to fit.
    Regular Member Gavin2.6's Avatar
    Liverpool
    Vehicle : 1.9 cdti SRI & 2.6 Vec B & Mk1 Fiesta XR2
    Trim : 2 batteries. 2k RMS. 2x 15 SPL's
    Engine : CDTI 200 16V
    Try getting them balanced again. Place that did my last tyres balanced them and i got bad wobble at 70+. Took them to be checked at another place and he said the balancing was well off and sorted them. Was fine aftere that.
    Also had an wobble on my vec b and that was the lower wishbones.
    Aug 2009
    herts
    1. My rear tyres were out of true due to the camber on the rear of the veccys. They put them on a balance machine, spun it and showed me as the tyre level jumped up and down as it spun.
    THAT was the cause of my vibration..
    Then..treated it to a 4 wheel alignment on a hunter machine. camber, balance, tracking etc.
    Spot on now, all speeds...a joy.
  1. Wheel Vibration
    By wayneg88 in forum Vectra C / Signum Car Chat
    Last Post: 12th November 2012, 02:20
  2. Wheel Vibration Under Braking
    By paulhb in forum Suspension, Wheels & Brakes
    Last Post: 13th July 2011, 21:22
  3. Wheel wobble/vibration Please help.
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 13th September 2010, 18:50
  4. Wheel vibration at over 70+
    By simonturner1975 in forum Suspension, Wheels & Brakes
    Last Post: 6th March 2010, 11:22
  5. wheel Vibration
    By Stephen S in forum Suspension, Wheels & Brakes
    Last Post: 20th November 2009, 16:57
