Thread: Pipe going into oil separator
    Regular Member Gazza36's Avatar
    Jan 2010
    Cornwall
    Default Pipe going into oil separator
    Hi, during a smoke test, the pipe going into the oil separator leaked smoke however I can't see how it's supposed to stay secured inside, it's needs to be removed for the manifold job so I wonder if anyone else has had this problem? Cheers, Gaz.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    YES it does move up and down slightly, theres an o-ring on the pipe, you dont have to take it out 2 do manifold! undo further along and take seperator off with the pipe connected still!. pic showing 2 places to undo.
    Jan 2010
    Cornwall
    Thing is I've already done it, and can't get it to go back in lol.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    It should go back in try turning it whilst putting it back in, also a little lubrication wouldnt harm.
    Sep 2009
    St Albans Herts
    Smile
    Quote Originally Posted by the-wizard View Post
    you say the sweetest things
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Quote Originally Posted by veralum View Post
  1. Brake servo pipe Help (Plastic Pipe)
    By Mark2.2 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2014, 15:41
  2. Oil in pipe
    By SlowCoach in forum Engine & Drivetrain
    Last Post: 4th December 2012, 00:22
  3. Pre Cat Pipe??
    By Governor in forum Diesel Engine related
    Last Post: 4th July 2010, 14:50
  4. Ball joint separator for track rod ends
    By Caveman_nige in forum Suspension, Wheels & Brakes
    Last Post: 26th May 2010, 16:00
  5. Pipe has came off
    By rob123 in forum Engine & Drivetrain
    Last Post: 13th October 2009, 23:23
