Thread: Denso Iridium Plugs & 2.2 non-direct
    Regular Member Spikeyİ's Avatar
    Dec 2005
    In the sponge-monkey tent
    Default Denso Iridium Plugs & 2.2 non-direct
    Well, just fitted a set of Denso Iridium ITV16 spark plugs to my 2.2 non-direct and frikkin WOW! Went out for a quick blast and what a difference
    Following on from Big Phil's Billing purchase (NGK Iridiums on the 3.2 GSi) and subsequent fitting by Mark, Phil reckons they're the dogs danglies so looked up some Iridiums for mine. NGK don't make them for my particular model, but I found some Denso's here: http://www.spark-plugs.co.uk which arrived this morning. After sorting out my lower front Irmy spoiler I set about fitting the plugs.
    As Mark suggested in Phil's thread they really couldn't be much easier to fit, it's just a case of undoing the 4 bolts holding down the spark pack (that'll be the black plate on top of the engine with the 'Ecotec' badge on, lifting it off the plugs and using a fairly long plug spanner to reach down the holes and undo the plugs. Wacked the new ones in, remembering from days of old not to overtighten them, spark pack back on and job done.
    Just went for a quick blast and the difference is fantastic, pulling away in first is SO much sharper, other than that though, you wont notice much difference until you get past about 2500rpm in other gears, then wow it just flies!
    Highly recommended upgrade for anyone with a 2.2 non-direct (probably will have a similar effect on the direct engine, but you'd have to check plug types first and fitting may be different.
    FAO: Mrs GSi, get hubby to fit a set of these before you go for your remap
    Sorry to Mark's wallet
    Bring on Santa Pod I say!!!
    Just here!!!
    I've just checked your link out sparky and they don't as per usual do em for the 1.8
    Dec 2005
    Is your engine the Z18XE Nick? If so then the NGK Iridiums like Phil has will fit, same part number from Courtenay Sport: BKR6EIX
    Regular Member d6oby's Avatar
    edinburgh
    Alright everyone,
    I am new here and have a question. I am going to buy the spark plugs but do they have to be gapped and to what size
    Dec 2005
    Quote Originally Posted by d6oby View Post
    Alright everyone,
    Hi mate, these days plugs should already come set to the right gap it's just a case of making sure you select the correct plug for your engine and year.
    Cirencester
    will it be the ITV16's for the Z18XER. the new 1.8VVTi engine?
    Dec 2005
    Quote Originally Posted by jonr View Post
    Have a look on the web site: http://www.spark-plugs.co.uk down the left hand side they have part finding do-dars, should be able to see if one of them makes them for this engine.
    [Ex]Admin Duncan's Avatar
    That do-dar never worked for me Spike. I was curious as to what they did for my engine as I was replacing them recently. It went through each stage of the drop down menu and submitting, then when it got to the last part where it had all the engine info, clicking submit did bu**er all!
    Dec 2005
    You might need to do it using Saab info D with the 2.0T, would be the same plug still i'd think?
  1. For Sale: Denso Iridium IK16s
    By Yugguy in forum Parts for sale
    Last Post: 26th November 2012, 20:24
  2. Cheapest Denso Iridium spark plugs?
    By GSiFan in forum Vectra C / Signum Car Chat
    Last Post: 30th October 2008, 23:30
  3. Iridium Plugs for the 2.2 direct are they safe?
    By sparky71a in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2008, 12:50
  4. Replies: 0
    Last Post: 13th April 2008, 20:14
