Results 1 to 2 of 2
Thread: 3.2 GSI Control Indicator Light, HELP!
    Regular Member corderz's Avatar
    Bradford
    Default 3.2 GSI Control Indicator Light, HELP!
    Right.....i have the control indicator light coming up (car with a spanner) when i turn the ignition on but goes once i start the car. Has anyone had the same problem and fixed it or anyone know how to fix?
    Regular Member v6vc's Avatar
    Jul 2009
    Planet Earth
    Vehicle : Vectra & Signum
    Trim : GSi & Design
    Engine : 3.2 V6 & 2.8 V6 T
    Year : 02/07
    Hi mate
    It's not really problem. I quite often have a spanner light on mine but goes out as yours does.
    It means that a fault has been logged and the spanner will go after a few 'clean starts' (about 35 I think). If it's on permanently then it's an issue.
    You can read your the fault codes by doing brake pedal and accelerator pedal trick. Run a search for 'reading fault codes for free' and you should find it.
  1. Cruise control indicator
    By 111 in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2010, 12:49
  2. 3.2 V6 control indicator light
    By ozziemokuy in forum Electrical & ICE (including SatNav)
    Last Post: 15th January 2010, 14:33
  3. control indicator lights on
    By matayou in forum Electrical & ICE (including SatNav)
    Last Post: 16th May 2009, 16:43
  4. Exhaust Control Indicator
    By D-S-Dave in forum Engine & Drivetrain
    Last Post: 30th December 2007, 22:57
  5. Help! - Control Indicator for Exhaust Warning Light
    By Madders in forum Electrical & ICE (including SatNav)
    Last Post: 8th December 2007, 20:21
